HP 12c Financial Calculator - Operating Modes and Clearing Procedures
Number representation
There are many different settings that allow the user to customize the HP 12c according to personal needs.
One of the basic settings is related to number representation. Basic financial operations usually show two decimals of currency, requiring two digits after the radix mark (decimal point), and this is the default representation. The HP 12c allows the number of decimal digits of the number in the display to be changed with the following keystroke sequence: [number key] where [number key] refers to any key from to .
Example 1
Calculate 4/7 and show the resulting value with four, six and seven digits after the radix mark.
Solution
The following keystroke sequence can be used:
Keystroke
Figure : Displaying the value with four digits
Figure : Displaying the value with six digits
Figure : Displaying the value with seven digits
An automatic rounding occurs with the representation of the number, but internally there is always a ten-digit mantissa and a two-digit exponent of ten for each number.
If it is necessary to check the mantissa of the number in display:
Keystroke
(hold for as long as needed).
Figure : Checking the mantissa of the number
There is also a scientific notation mode that shows numbers with seven significant digits and the exponent of ten. This is useful if a number is too large to be displayed normally or if a number needs to be displayed in this manner to be consistent with other values.
Keystroke
Figure : Displaying numbers with seven digits and the exponent of ten
If there is a need to change the radix mark from dot (default) to comma and conversely, the HP 12c allows toggling from one to the other with the following sequence:
  • With the calculator off, press and hold .
  • Turn the calculator on.
  • Release .
Figure : Changing the radix mark from dot to comma
Settings and annunciators
Figure 7 shows all annunciators that may become visible in an HP 12c display when in normal operation:
Figure : Displaying the annunciator symbols on the screen
Their meanings are:
Symbols
(flashing)
The batteries are nearly exhausted and must be replaced.
f or g
The corresponding or key was pressed and its action is still active; press to override.
BEGIN
The keystroke sequence was performed to indicate that payments occur in the beginning of the composition periods; to change back to end mode and deactivate the annunciator, press .
D.MY
The keystroke sequence was performed to indicate that dates are entered and shown in DD.MMYYYY format; to change the mode to M.DY and deactivate the annunciator, press .
C
The keystroke sequence was performed to indicate that odd-periods are considered with compound interest rate when TVM operations are performed; press again to toggle the annunciator condition and use simple interest for odd-periods.
PRGM
Either program mode is active or a program is running. If program mode is active, press to return to normal operation and deactivate the annunciator; if 'Running' is flashing in the display then a program is being executed and pressing will stop it.
If 'Running' is flashing in the display and the 'PRGM' annunciator is not shown, then an internal function is being performed and pressing will not stop it.
Memory organization
In the HP 12c, memory is organized as a set of registers that can hold a valid number representation. All memory available in the HP 12c to the user is represented in Figure 8 in terms of registers. Their contents in the figure are their default contents when memory is cleared or when the calculator is first turned on.
Figure : Displaying the default contents
Registers R0 to R9 and R.0 to R.9 are "general purpose" registers, and they can be accessed either directly by the user or by some internal functions. The shaded area represents the registers that can be automatically converted into program steps. Although registers R1 to R6 are general purpose registers as any other, their contents are used by statistical functions. Financial registers , , , and are used by TVM, Bond, Depreciation and Cash-Flow functions, but can also be used to hold any valid number.
How to selectively clear memory contents
The "master clear" of the HP 12c is accomplished when the following sequence is executed:
  • Release .
If the operation is successful, the display shows:
Figure : The screen displays after clearing the memory
The HP 12c memory contents now match the ones shown in Figure 8.
It is possible to clear specific parts of the HP 12c memory with the use of the clearing functions under -CLEAR-, on the keyboard. The different functions included are:
Keystroke
Clears the contents of registers R1 to R6 and the stack registers X, Y, Z and T to 0.00 without changing any other register contents. This allows new statistic summations to be collected.
If the calculator is in program mode (PRGM annunciator on), clears the first eight program steps to () and free all registers used by programs for data storage, if any. If the calculator is in normal (run) mode, only positions the program memory to step # 00.
Clears the five financial registers , , , and to zero.
Clears all registers containing valid numbers to their default contents, as shown in Figure 8. does not clear any program instruction, even if they are stored in registers converted to program steps.
Clears f annunciator and any partial keystroke sequence (, , , , , etc)
