SUPPORT COMMUNICATION- SECURITY BULLETIN
Document ID: c01886100
Version: 3
HPSBPI02472 SSRT090196 rev.4 - Certain HP Color LaserJet Printers, Remote Unauthorized Access to Data, Denial of Service
Notice:: The information in this security bulletin should be acted upon as soon as possible.
Release date : 24-Sep-2009
Last updated : 17-Jul-2017
Potential Security Impact:
Remote unauthorized access to data, Denial of Service (DoS)
VULNERABILITY SUMMARY
A potential security vulnerability has been identified with certain HP Color LaserJet printers. The vulnerability could be exploited remotely to gain unauthorized access to data or to create a Denial of Service (DoS).
Reference Number
CVE-2009-3842
SUPPORTED SOFTWARE VERSIONS*: ONLY impacted versions are listed.
HP Color LaserJet CM3530 Multifunction Printer (MFP) with firmware 53.021.2 (earlier versions are not vulnerable)
HP Color LaserJet CP3525 Printer with firmware 05.058.4 (earlier versions are not vulnerable)
BACKGROUND
CVSS 2.0 Base Metrics
Reference
Base Vector
Base Score
CVE-2009-3842
(AV:N/AC:L/Au:N/C:P/I:P/A:C)
9.0
Information on CVSS is documented in HP Customer Notice: HPSN-2008-002.
RESOLUTION
HP has provided firmware updates for impacted printers as set forth in the table below. To obtain the updated firmware, go to the HP Software and Drivers page for your product and find the firmware update from the list of available software.
Resolved in Firmware Version
HP Color LaserJet CM3530 MFP
53.031.4 or subsequent
05.059.3 or subsequent
Note: Each firmware update has instructions for finding the firmware version installed on the product.
PRODUCT SPECIFIC INFORMATION
None
Third Party Security Patches: Third party security patches that are to be installed on systems running HP software products should be applied in accordance with the customer's patch management policy.
Support: For issues about implementing the recommendations of this Security Bulletin, visit http://www.hp.com/go/contacthp to learn about your HP support options.
Report: To report a potential security vulnerability with any HP supported product, send email to: hp-security-alert@hp.com.
Subscribe: To initiate a subscription to receive future HP Security Bulletin alerts via email, visit https://h41369.www4.hp.com/alerts-signup.php?lang=en&cc=US&jumpid=hpsc_profile.
Security Bulletin Archive: To view released Security Bulletins, search the HP Support Site for "security bulletin".
Software Product Category: The Software Product Category is represented in the title by the two characters following HPSB.
PI
HP Printing and Imaging
HF
HP Hardware and Firmware
GN
HP General Software
It is strongly recommended that security related information being communicated to HP be encrypted using PGP, especially exploit information.
To get the security-alert PGP key, please send an e-mail message as follows:
Subject: get key
System management and security procedures must be reviewed frequently to maintain system integrity. HP is continually reviewing and enhancing the security features of software products to provide customers with current secure solutions.
"HP is broadly distributing this Security Bulletin in order to bring to the attention of users of the affected HP products the important security information contained in this Bulletin.HP recommends that all users determine the applicability of this information to their individual situations and take appropriate action.HP does not warrant that this information is necessarily accurate or complete for all user situations and, consequently, HP will not be responsible for any damages resulting from user's use or disregard of the information provided in this Bulletin.To the extent permitted by law, HP disclaims all warranties, either express or implied, including the warranties of merchantability and fitness for a particular purpose, title and non-infringement."
REVISION HISTORY : Version:1 (rev.1) - 18 November 2009 Initial release; Version:2 (rev.2) - 10 December 2009 Corrected product versions in SUPPORTED SOFTWARE VERSIONS section; Version:3 (rev.3) - 20 June 2011 Corrected model number; Version:4 (rev.4) - 17 July 2017 Replaced download process. Added boilerplate reuse c05565415
