Compaq 300B/500B Microtower Business PC Product Specifications
Product description
The Compaq 300B/500B Microtower Business PC helps with the business basic computing functions at a price that won’t break bank.
Product features
Feature
  • Intel G41 Express
  • Intel I/O Controller Hub 7 (ICH7)
Processors
Intel Celeron Processors:
  • Intel Celeron 440 Processor (2.00 GHz, 512KB L2 cache, 800 MHz FSB)
  • Intel Celeron 450 Processor (2.2 GHz, 512K L2 cache, 800 MHz FSB)
Intel Celeron Dual-Core Processors:
  • Intel Celeron E1500 Processor (2.2 GHz, 512K L2 cache, 800 MHz FSB)
  • Intel Celeron E1600 Processor (2.4 GHz, 512K L2 cache, 800 MHz FSB)
  • Intel Celeron E3200 Processor (2.4 GHz, 1MB L2 cache, 800 MHz FSB)
  • Intel Celeron E3300 Processor (2.5 GHz, 1MB L2 cache, 800 MHz FSB)
Intel Pentium Dual-Core Processors:
  • Intel Pentium E5300 Processor (2.6 GHz, 2MB L2 cache, 800 MHz FSB)
  • Intel Pentium E5400 Processor (2.70 GHz, 2MB L2 cache, 800 MHz FSB)
  • Intel Pentium E6300 Processor (2.80 GHz, 2MB L2 cache, 1066 MHz FSB)
  • Intel Pentium E6500 Processor (2.93 GHz, 2MB L2 cache, 1066 MHz FSB)
Intel Core 2 Duo Processors:
  • Intel Core 2 Duo E7500 Processor (2.93 GHz, 3MB L2 cache, 1066 MHz FSB)
  • Intel Core 2 Duo E7600 Processor (3.06 GHz, 3MB L2 cache, 1066 MHz FSB)
  • Intel Core 2 Duo E8400 Processor (3.00 GHz, 6MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Duo E8500 Processor (3.16 GHz, 6MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Duo E8600 processor (3.33 GHz, 6MB L2 cache, 1333 MHz FSB)
Intel Core 2 Quad Processors:
  • Intel Core 2 Quad Q8300 processor (2.50 GHz, 4MB L2 cache, 1333 MHz FSB)
Intel processor numbers are not a measure of performance. Processor numbers differentiate features within each processor family, not across different processor families.
System memory
  • 1GB DDR3 Synch DRAM 1333 MHz Non-ECC (1 x 1GB)
  • 2GB DDR3 Synch DRAM 1333 MHz Non-ECC (2 x 1GB)
  • 2GB DDR3 Synch DRAM 1333 MHz Non-ECC (1 x 2GB)
  • 3GB DDR3 Synch DRAM 1333 MHz Non-ECC (1 x 2GB, 1x1GB)
  • 4GB DDR3 Synch DRAM 1333 MHz Non-ECC (2 x 2GB)
Storage
Optical Drives (Serial ATA):
  • SATA DVD-ROM Drive
  • SATA SuperMulti LightScribe DVD writer drive
Media Reader: HP 6-in-1 Media Card Reader (part of front I/O assembly)
Keyboard/Mouse
Keyboard:
  • Compaq USB standard keyboard
  • HP Mini USB keyboard (optional)
Mouse:
  • Compaq USB Optical Scroll Mouse
Graphics
  • Integrated Intel Graphics Media Accelerator 4500
  • NVIDIA GeForce G210 HDMI PCIe x16 Graphics Card
  • ATI Radeon HD 4350 HDMI PCIe x16 Graphics Card
Miscellaneous
  • HP FireWire / IEEE 1394 PCI Card (full height)
  • HP Serial/Parallel PCI Card (full height)
Power supply
300 W ATX power supply
Communications
Specification
Communication
  • Integrated Realtek RTL8103EL 10/100 Ethernet Controller
  • Intel Gigabit CT Desktop NIC (optional)
  • LSI PCIe x1 Hi-Speed 56K International SoftModem (optional)
  • HP PCIe Wireless 802.11b/g/n
Miscellaneous
Audio
Specification
Audio
  • Realtek ALC662 High Definition audio codec
  • 3D audio compliant and HD audio compatible
  • HP USB Thin powered speakers
Graphics
Specification
Graphics
Physical specifications
Specification
Chassis dimensions (H x W x D)
0.384 x 0.166 x 0.428 m (15.11 x 6.54 x 16.87 in)
Packaged dimensions
0.585 x 0.498 x 0.245 m (23.03 x 19.61 x 9.65 in)
Shipping weight
14.0 kg (30.8 lb)
System weight
10.2 kg (22.4 lb)
Temperature
Operating: 10° to 35°C (50° to 95°F)
Non-operating: –30° to 60°C (–22° to 140°F)
Relative humidity
Operating: 10% to 90% (non-condensing at ambient)
Non-operating: 5% to 95% (non-condensing at ambient)
Maximum altitude (unpressurized)
Operating: 3048 m (10,000 ft)
Non-operating: 9000 m (30,000 ft)
Operating temperature is de-rated 1°C per 300 m (1000 ft) to 3000 m (10,000 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 10°C/hr. The upper limit may be limited by the type and number of options installed.
Power
300 W ATX Power Supply – PFC/non-PFC with a 115/230 V line switch
Software/OS
Feature
Operating System
  • Genuine Windows 7 Professional Edition 32
  • Microsoft Windows XP
  • Windows Vista
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
