    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP LaserJet 1020 and 1022 Printer Series - Setting Up the LaserJet (Hardware)
  • Unpack the printer and check the contents
  • Remove the packing tape
  • Install the print cartridge
  • Connect the power cord
  • Turn on the product
  • Load plain paper
Setting up the printer
Follow these steps in order.
Step one: Unpack the printer and check the contents
  1. Remove the product from the box.
    Figure : Remove the product from the box
    Illustration: Remove the product from the box
  2. Check the contents of the box.
Step two: Remove the packing tape
  1. Open the print cartridge access door.
    Figure : Open the print cartridge access door
    Illustration: Open the print cartridge access door
  2. Remove all the orange packing tape from the product.
    Figure : Remove the orange packing tape
    Illustration: Remove the orange packing tape
Step three: Install the print cartridge
  1. Open the output tray support, and then open the print cartridge door.
    Figure : Open the output tray support
    Illustration: Open the output tray support
    Figure : Open the print cartridge door
    Illustration: Open the print cartridge door
  2. Remove the new print cartridge from the package.
    Hold the print cartridge at each end to prevent damage to the print cartridge.
    Figure : Remove the new print cartridge from the package
    Illustration: Remove the new print cartridge from  the  package
  3. Gently rock the print cartridge back and forth to distribute the toner evenly.
    Figure : Rock the print cartridge back and forth
    Illustration: Rock the print cartridge
back and forth
  4. Pull the orange tab until all the sealing tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling.
    Figure : Pull the orange tab to remove the sealing tape
    Illustration: Pull the tab to remove the sealing tape
  5. Insert the print cartridge in the product, and then close the print cartridge door.
    Figure : Insert the print cartridge
    Illustration: Insert the print cartridge
Step four: Connect the power cord
Connect the power cord to the back of the product, and then plug the power cord into an electrical outlet.
Figure : Connect the power cord
Illustration: Connect the power cord
Step five: Turn on power
Press the Power switch to turn on the product.
Figure : Press the Power switch
Illustration: Press the Power switch
Step six: Load plain paper
  1. Slide the paper width and length guides to their outmost positions.
    Figure : Slide out the paper guides
    Illustration: Slide out the paper guides
  2. Load the paper into the paper tray, and then slide the paper width and length guides inward until they stop at the edge of the paper.
    Do not use stapled, wrinkled, folded, or damaged paper.
    Figure : Load the paper and slide in paper guides
    Illustration: Load the paper and slide in paper guides
  3. Insert the input tray cover over the main input tray.
    Figure : Insert the input tray cover
    Illustration: Insert the input tray cover
  4. Close the input tray.
    Figure : Close the input tray
    Illustration: Close the input tray cover
