HP Indigo WS6000 Digital Press - Cleaning the PTE
  • Clean the PTE cover weekly, or whenever it is dirty.
  • To determine if the cover is dirty, examine the strips with a magnifying glass. If the cover is dirty, you will notice that the screen dots seem splattered. The screen dots should be round.
    Wear safety gloves and glasses for this procedure.
To clean the PTE:
  1. Press an Emergency Stop button and open the front door.
  2. Remove the PTE from the press.
    Figure : Removing the PTE
  3. Clean the PTE cover using a lint-free wipe dampened with imaging oil.
    Figure : Cleaning the PTE cover
  4. Check the air knife.
    Figure : Checking the air knife
  5. Reinstall the PTE into the press.
  6. Close the front door and release the Emergency Stop button.
