    Fix HP Printer issue on macOS
HP Indigo WS6000 Digital Press - Rewinder
The rewinder, located at the exit side of the press, is used to rewind the substrate.
The rewinder is controlled through a touchscreen panel.
    Figure : Rewinder
  1. Touchscreen panel
  2. Splicing table
  3. Transportation handle
  4. Dancer arm
  5. Electrostatic brush
  6. Wheels
  7. Ultrasonic sensor
  8. Expanding shaft
  9. Pads
  10. Packer arm (optional)
  11. Web guide sensor
  12. Clamps
  13. Emergency stop button
  14. Tape dispenser
