HP Indigo WS6000 Digital Press - Using the press
To use the press:
  1. performed the previous day.
  2. Put the press in Ready status. On the touchscreen, touch Get Ready. The alarm will sound and the button will change. Touch the button again. The press drums begin to roll and the various subsystems power up. When the preset conditions are met, the press status changes to Ready.
  3. Load a job.
  4. Touch Print or Proof.
  5. At the rewinder, check the output placement, color, etc. Adjust if necessary.
  6. When the job has finished printing, the press goes to Ready status. After 20 minutes, the press goes to Standby status.
  7. When you have finished work for the day, perform the end of day routines and turn the press off.
