HP ProBook 4410s Notebook PC - Removing and Replacing the Palm rest
This document is provided to assist in removing and replacing the Palm rest for the HP ProBook 4410s Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head P1 screwdriver.
Parts required
The replacement part number will vary depending on the Palm rest that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Palm rest - For use in black computers with 15 inches displays
535868-001 (Modified)
No
Palm rest - For use in red computers with 15 inches displays
572728-001 (Original)
No
Palm rest - For use in black computers with 14 inches displays
535867-001 (Modified)
No
Palm rest - For use in red computers with 14 inches displays
572727-001 (Original)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Palm rest, click on the link below. Or use the product video listing on the HP Services Media Library then select Palm rest from the menu on the upper left hand side of the screen.
Click here to view the Palm rest removal video (right-click on the link to open in a new window/tab).
Palm rest removal
  2. Remove the three 3mm P1 Phillips broad head screws that secure the palm rest to the base enclosure.
  3. Slide the palm rest toward the center of the notebook.
  4. Flip the palm rest toward the center of the notebook and rest it face down on the base enclosure.
  5. Gently lift the locking bar out of the palm rest ZIF connector and remove the ribbon cable
    Use care to prevent damaging the ZIF connector and ribbon cable.
  6. Remove the palm rest from the base enclosure.
Palm rest replacement
  1. Place the palm rest face down in the center of the base enclosure.
  2. Insert the palm rest ribbon cable into the ZIF connector on the system board and push the locking bar down to secure the cable in the connector.
  3. Flip the palm rest toward the front edge of the notebook and set it into position on the base enclosure.
  4. While pressing down, slide the palm rest toward the front of the notebook until it is secure and flush with the front edge of the base enclosure.
  5. Replace the three 3mm P1 Phillips broad head screws that secure the palm rest to the base enclosure.
Parts return
