HP 50g Calculator - Selecting the Clock Display
This document explains how to select the clock display for HP 50g calculator.
To select a clock display:
  1. Press the button to activate the ‘CALCULATOR MODES’ input form.
  2. Press the soft menu key to display the 'DISPLAY MODES' input form.
  3. Press the down arrow key, , four times, to get to the ‘Header’ field. The Header field will be highlighted.
  4. Use the right arrow key () to select the field in front of ‘_Clock’ or ‘_Analog’.
  5. Use the soft menu key to toggle the settings. Settings preceded by the check mark are the active settings.
If the ‘_Clock’ option is selected, the time of the day and date will be shown in the upper right corner of the display. If the ‘_Analog’ option is also selected, an analog clock, rather than a digital clock, will be shown in the upper right corner of the display. If the ‘_Clock’ option is not selected, or the header is not present, or is too small, the date and time of day will not be shown in the display. To change the size of the header, use the cursor keys to highlight the field after Header. Press the menu key. Select the desired setting and press .
