Compaq 610 Notebook PC Product Specifications
Product image
Product features
Feature
Models with integrated graphics: Mobile Intel GLE960 Express Chipset with ICH8M, 533 MHz front side bus or Mobile Intel GME965 Express Chipset with ICH8M, 800 MHz front side bus.
Models with discrete graphics: Mobile Intel PM965 Express Chipset with ICH8M, 800 MHz front side bus.
Processors
  • Intel Core 2 Duo Processor T5870 (2.0 GHz, 2 MB L2 cache, 800 MHz FSB)
  • Intel Dual-Core Celeron Processor T1500 (1.86 GHz, 512 KB L2 cache, 533 MHz FSB)
  • Intel Celeron Processor 560 (2.13 GHz, 1 MB L2 cache, 533 MHz FSB)
Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
Memory
Standard: 512 MB, 1 GB, or 2 GB 667 MHz or 800 MHz DDR2 SDRAM*; two SODIMM slots supporting dual channel memory.
Maximum: Upgradeable to 4 GB** total memory.
Dual-channel : Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
* Models with Mobile Intel GLE960 Express Chipset use this memory at a maximum memory speed of 533 MHz. Models with Mobile Intel GME965 or Mobile Intel PM965 Express Chipset use this memory at a maximum memory speed of 667 MHz.
** 4 GB maximum requires Mobile Intel GME965 or PM965 Express Chipset.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed. Full availability of 4 GB or more of memory requires Windows Vista Business 64-bit or Linux. With Windows 32-bit operating systems, the amount of usable memory is dependent upon your configuration, so that above 3 GB all memory may not be available due to system resource requirements.
Graphics
Models with integrated graphics: Mobile Intel Graphics Media Accelerator X3100, up to 384 MB shared system memory.
Models with discrete graphics: ATI Mobility Radeon HD 4330 graphics with 256 MB dedicated video memory and HyperMemory support.
Microsoft DirectX 10.1 (discrete),10 (integrated) capable.
Internal
  • 15.6 inches diagonal LED-backlit HD 16:9 widescreen anti-glare (1366 x 768 resolution)
  • 15.6 inches diagonal LED-backlit HD 16:9 widescreen BrightView (1366 x 768 resolution)
External
  • Up to 32 bit per pixel color depth
  • VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Keyboard
The 101/102-key compatible keyboard features an industry standard, full-pitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. International key layouts are available. Other features include an integrated numeric keypad, hotkeys for instant access to power conservation, brightness, and other features, 19-mm x 19-mm key pitch (center-to-center spacing), 2.5-mm stroke, comfort-dished keycaps, and bright key legends for improved visibility in low light conditions.
Pointing device
Touchpad with scroll zone, two pick buttons.
Expansion card slots
ExpressCard/34 slot Supports ExpressCard/34 (34 mm x 75 mm x 5 mm)
Secure Digital slot Supports SD (Secure Digital), and MMC (MultiMedia Card)
Storage
Hard drives 160/250/320/500 GB 5400 rpm SMART SATA
DriveGuard The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive.
Fixed optical drives:
  • DVD ROM Drive
  • DVD+/-RW SuperMulti DL LightScribe Drive
Power Supply
Models with integrated graphics: External 65 W AC adapter
Models with discrete graphics: External 90 W AC adapter
Battery
  • 6-cell (47 WHr) high capacity Lithium-Ion
  • 8-cell (63 WHr) high capacity Lithium-Ion
Communications
Features
Integrated Marvell 10/100 NIC
Ethernet Features:
  • 10 Mbit/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mbit/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • Auto-Negotiation (Automatic Speed Selection)
  • Full Duplex & Half Duplex Operation at all Speeds
  • IEEE 802.1p QoS (Quality of Service) Support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
Power Management: ACPI compliant – multiple power modes. Situation-sensitive features reduce power consumption.
Performance Features: TCP/IP/UDP Checksum Offload (configurable).
Intel PRO/Wireless 3945ABG Network Connection
Wireless LAN Standards:
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
Broadcom 4312G 802.11b/g WiFi Adapter
  • IEEE 802.11b
  • IEEE 802.11g
Broadcom 4322AGN 802.11a/b/g/draft-n WiFi Adapter
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n *
* The specifications for 802.11n draft 2.0 are draft specifications and are not final. If the final specifications differ from the draft specifications, it may affect the ability of the notebook to communicate with other 802.11n WLAN devices.
Audio/visual
Features
Audio
  • High Definition Audio support
  • Integrated mono speaker
  • Stereo headphone/line out
  • Stereo microphone in
Visual
  • Optional integrated 2MP webcam
Power
Features
Stand-Alone Power Requirements (AC Power)
  • Nominal Operating Voltage: 18.5 V
  • Average Operating Power:
    • Models with integrated graphics: 17.6 W
    • Models with discrete graphics: 19.6 W
  • Max Operating power: < 90 W
Power Conservation
  • Hibernation
  • Standby
  • ACPI compliance
Wireless devices
Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Wireless LAN is factory configurable or available as an option to be added later. Broadband Wireless (WWAN) requires Windows Vista Business or Windows XP Professional and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth is also available (factory configurable only) and can be combined with any of the supported wireless LAN and wireless WAN options.
Features
All 802.11 integrated wireless LAN options
  • Wi-Fi certified
  • Cisco Compatible Extensions support (Version 4.0) with Microsoft Windows XP
  • Wired Equivalent Privacy (WEP) support up to 128-bit keys
  • Wi-Fi Protected Access (WPA) and WPA2 support
  • 802.1x authentication support, including EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, and LEAP
  • Advanced Encryption Standard (AES) support
  • Dual antennas integrated in the display enclosure
Integrated support for 802.11 a, b and g Cisco Compatible Extensions support Up to 54 mbps data rate.
Broadcom 4322AGN 802.11a/b/g/draft-n Wi-Fi Adapter
Integrated support for 802.11a, b, g, and n draft 2.0 Cisco Compatible Extensions support Up to 300 mbps data rate.
Integrated support for 802.11 b and g Cisco Compatible Extensions support Up to 54 mbps data rate.
HP Integrated Module with Bluetooth Wireless Technology
Bluetooth Specification v2.1 compliant Works with a wide range of Bluetooth devices.
Physical specifications
Features
Dimensions (HxWxD)
1.26 (at front) x 14.64 x 10.01 in 32.0 (at front) x 371.8 x 254.3 mm
Starting at 5.5 lb (2.49 kg)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 6-cell battery, 160GB hard drive, 1 GB memory, and optical drive. Weight varies by configuration and components.
Temperature
Operating: 32° to 95° F (0° to 35° C) (not writing optical), 41° to 95° F (5° to 35° C) (writing optical)
Non-operating: -4° to 140° F (-20° to 60° C)
Relative Humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 101.6° F (38.7° C) maximum wet bulb temperature
Shock
Operating: 125 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random Vibration
Operating: 0.75 grms
Non-operating: 1.50 grms
Altitude (unpressurized)
Operating: –50 to 10,000 ft (–15.24 to 3,048 m)
Non-operating: –50 to 40,000 ft (–15.24 to 12,192 m)
Software/OS
Feature
Operating System
  • Microsoft Windows XP
  • Windows Vista
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
