HP Indigo 7000 Digital Press - Color Calibration procedures
To perform the short or full color calibration procedure:
  1. On the press software menu, select Print Quality. The Print Quality panel opens.
  2. Touch Color Calibration. The Color Calibration wizard opens.
  3. Select the Short or Full color calibration type,
  4. Select a method to run the calibration — Skip to print uses default substrate, screening and ink parameters to run the calibration. Step by step allows you to customize the calibration parameters.
    When performing a Step by Step calibration, choose a the same substrate or a substrate from the same group as the calibration substrate.
    Figure : Color Calibration Wizard
  5. At the wizard Method step, select the Standard or Custom calibration method.
    • The Standard calibration method allows you to continue the calibration with no additional options.
    • The Custom calibration method allows you to choose to include the Velectrode calibration and default parameters to overcome print quality issues, as well as modifying target optical density of 100% ink coverage values.
    Figure : Color Calibration method
  6. Follow the wizard instructions to complete the calibration procedure.
Country: Flag Vietnam
