    Fix HP Printer issue on macOS
Printer Specifications for HP Officejet 7000, Special Edition, and Advantage Wide Format Printers
Product specifications
This document contains specifications for the product, including model numbers, system requirements, and print speed.
Product models
Figure : HP Officejet 7000 Wide Format Printer
Photo of Officejet 7000 Wide Format Printer
Printer model
Part number
HP Officejet 7000 Wide Format Printer (E809a)
C9299A
HP Officejet 7000 Wide Format Special Edition Printer (E809b)
C9316A
HP Officejet 7000 Wide Format Advantage Printer (E809c)
C9317A
System requirements
The following tables contain the minimum system requirements and recommended system requirements for supported Windows and Macintosh operating systems.
Windows system requirements
Supported Windows operating systems: Windows XP, Windows Vista
For Windows XP SP 1 Starter Edition, and Windows Vista Starter Edition only the print driver and Toolbox are available.
Component
Minimum system requirement
Recommended system requirement
Processor
Windows XP (32-bit) Service Pack 1
Intel Pentium II or Celeron processor
Intel Pentium III or higher processor
Windows Vista
800 MHz 32-bit (x86) or 64-bit (x64) processor
1 GHz 32-bit (x86) or 64-bit (x64) processor
RAM
512 MB
512 MB
Windows Vista
512 MB
1 GB
Free disk space
225 MB
360 MB
Windows Vista
902 MB
1056 MB
Browser
Microsoft Internet Explorer 6.0 or later
Windows Vista
Microsoft Internet Explorer 7.0
Other
Adobe Acrobat Reader 5.0 or later
A USB cable can be purchased from any reputable dealer.
Macintosh system requirements
Supported Windows operating systems: Mac OS X (v.10.4, v.10.5)
Component
Processor
PowerPC G4, G5, or Intel Core processor
Memory
256 MB
512 MB
Free disk space
500 MB
500 MB
Other
Quick Time 5.0 or later
Features and capacities
Component
Specification
Connectivity
USB support
USB 2.0-compliant high speed
Network support
Wired network
Product processor and memory
Product processor
192 MHz ARM946ES, ETM9 (medium)
Product memory
64 MB built-in RAM, 32 MB built-in Flash ROM
Font support
US fonts: CG Times, CG Times Italic, Universe, Universe Italic, Courier, Courier Italic, Letter Gothic, Letter Gothic Italic.
Physical dimensions
Dimension
Measurement
Height
181 mm (7.1 inches)
Width
575 mm (22.7 inches)
Depth
402 mm (15.8 inches)
6.7 kg (14.8 lb)
Cartridges
The printing mechanism for this product involves a printhead and four cartridges. Review the following tables for printheads and cartridges that are compatible with your product.
Printhead
Example
Printhead
Ordering the printhead
The printhead is available only from HP Parts Store.
  1. If you are in Asia Pacific, the site directs you to a service center in your area.
  2. Search for part number CN643A.
  3. Follow the instructions to order the printhead assembly.
Cartridges
Cartridge
Region
Black
The Americas
Europe
Middle East and Africa
Asia Pacific
HP 920 Black Officejet Ink Cartridge
Cyan
Europe
Asia Pacific
HP 920XL* Cyan Officejet Ink Cartridge
The Americas
HP 920 Cyan Officejet Ink Cartridge
Magenta
Europe
Asia Pacific
HP 920XL Magenta Officejet Ink Cartridge
The Americas
HP 920 Magenta Officejet Ink Cartridge
Yellow
Europe
Asia Pacific
HP 920XL Yellow Officejet Ink Cartridge
The Americas
HP 920 Yellow Officejet Ink Cartridge
Paper-handling specifications
Use the following tables to determine the paper-handling specifications for your product.
Paper tray capacities
Tray
Type
Capacity*
Input tray
Paper
60 to 105 g/m2 (16 to 28 lb bond)
Up to 150 sheets of plain paper (15 mm or 0.59 inch stacked)
Transparencies
n/a
Up to 55 sheets (15 mm or 0.59 inch stacked)
Photo paper
280 g/m2 (75 lb bond)
Up to 40 sheets (12 mm or 0.47 inch stacked)
Labels
n/a
Up to 100 sheets (17 mm or 0.67 inch stacked)
Envelopes
75 to 90 g/m2 (20 to 24 lb bond envelope)
Up to 15 sheets (10 mm or 0.39 inch stacked)
Cards
Up to 200 g/m2 (110 lb index)
Up to 40 cards (10 mm or 0.39 inch stacked)
Output tray**
All supported media
n/a
Up to 100 sheets of plain paper (text printing)
*Maximum Capacity
**Output tray capacity is affected by the type of paper and the amount of ink you are using. HP recommends emptying the output tray frequently.
Supported standard paper sizes
Paper type
Paper size
U.S. Letter*
216 x 279 mm (8.5 x 11 inches)
U.S. Legal
216 x 356 mm (8.5 x 14 inches)
A4*
210 x 297 mm (8.3 x 11.7 inches)
U.S. Executive
184 x 267 mm (7.25 x 10.5 inches)
B5* (JIS)
182 x 257 mm (7.17 x 10.12 inches)
B5 (ISO)
176 x 250 mm (6.9 x 9.8 inches)
A5*
148 x 210 mm (5.8 x 8.3 inches)
A6*
105 x 148 mm (4.13 x 5.83 inches)
HV*
101 x 180 mm (4.0 x 7.1 inches)
Plain paper*
127 x 178 mm (5 x 7 inches)
* Borderless printing supported.
Supported B size
Paper type
Paper size
B size*
279 x 356 mm (11 x 14 inches)
B size*
305 x 305 mm (12 x 12 inches)
B4 (JIS)
257 x 364 mm (10.12 x 14.33 inches)
Tabloid*
279 x 432 mm (11 x 17 inches)
Super B*
330 x 483 mm (13 x 19 inches)
A3*
297 x 420 mm (11.69 x 16.54 inches)
A3+*
330 x 483 mm (12.99 x 18.98 inches)
+ The device is compatible with plain and inkjet hagaki from Japan Post only. It is not compatible with photo hagaki from Japan Post.
Supported envelopes
Paper type
Paper size
U.S. #10 Envelope
105 x 241 mm (4.12 x 9.5 inches)
C6 Envelope
114 x 162 mm (4.5 x 6.4 inches)
Japanese Envelope Chou #3
120 x 235 mm (4.7 x 9.3 inches)
Japanese Envelope Chou #4
90 x 205 mm (3.5 x 8.1 inches)
Kakou Envelope #2
240 x 332 mm (9.45 x 13.07 inches)
Monarch Envelope
99 x 191 mm (3.88 x 7.5 inches)
Card Envelope
111 x 162 mm (4.4 x 6 inches)
No. 6 3/4 Envelope
91 x 165 mm (3.6 x 6.5 inches)
Supported cards
Paper type
Paper size
Index card
76.2 x 127 mm (3 x 5 inches)
Index card
102 x 152 mm (4 x 6 inches)
Index card
127 x 203 mm (5 x 8 inches)
A6 card*
105 x 148.5 mm (4.13 x 5.83 inches)
Hagaki+*
100 x 148 mm (3.9 x 5.8 inches)
Supported photo paper
Paper type
Paper size
Photo paper*
Photo paper*
Photo paper*
203 x 254 mm (8 x 10 inches)
Photo paper 4 x 6 tab*
Photo paper 4 x 8 tab*
100 x 200 mm (4 x 8 inches)
Photo paper 10 x 15 tab*
100 x 150 mm (10 x 15 inches)
Photo L
89 x 127 mm (3.5 x 5 inches)
2L
178 x 127 mm (7.0 x 5.0 inches)
B5*
182 x 257 mm (7.2 x 10.1 inches)
Cabinet size*
120 x 165 mm (4.7 x 6.5 inches)
Ofuku hagaki+
200 x 148 mm (7.9 x 5.8 inches)
Other supported paper
Paper type
Paper size
Custom-sized paper
Between 76.2 to 330.2 mm wide and 101 to 1117 mm long (3 to 13 inches wide and 4 to 43.9 inches long)
Printing specifications
  • Black print resolution: Up to 1200 dpi with pigmented black ink
  • Color print resolution: HP enhanced photo quality (up to 4800 x 1200 dpi Optimized on HP Premium Plus photo papers with 1200 x 1200 input dpi)
  • Print method: Drop-on-demand thermal inkjet printing
  • Device languages: HP PCL 3 and HP PCL 3 GUI
  • Duty cycle: Up to 7000 pages per month
  • Print speed: In pages per minute (ppm)*
    Print Mode
    Print speed*
    Black
    Color
    Draft
    31
    30
    ISO
    7
    7
    LQS
    6
    6
    *See www.hp.com/go/inkjetprinter for details. (in English)
Power specifications
  • Power supply: Universal power adapter (external)
  • Power requirements:
    • Input voltage: 100 to 240 VAC (± 10%), 50 to 60 Hz (± 3Hz)
    • Output voltage: 32 Vdc, 1560 mA
  • Power consumption: 34.03 watts
Acoustic emission specifications
Print in Draft mode, noise levels per ISO 7779
  • Sound pressure (bystander position): LpAd 54 (dBA)
  • Sound power: LwAd 6.7 (BA)
Environmental specifications
Review the following sections for environmental specifications.
Operating environment
  • Operating temperature: 5° to 40° C (41° to 104° F)
  • Recommended operating conditions: 15° to 32° C (59° to 90° F)
  • Recommended relative humidity: 20 to 80% noncondensing
Storage environment
  • Storage temperature: -40° to 60° C (-40° to 140° F)
  • Storage relative humidity: Up to 90% noncondensing at a temperature of 60° C (140° F)
Energy Star
This product is designed to reduce power consumption and save natural resources without compromising product performance. It has been designed to reduce total energy consumption both during operation and when the device is not active. This product qualifies for ENERGY STAR®, which is a voluntary program established to encourage the development of energy-efficient office products.
ENERGY STAR is a U.S. registered service mark of the U.S. EPA. As an ENERGY STAR partner, HP has determined that this product meets ENERGY STAR guidelines for energy efficiency.
For more information, go to the Energy Star website (in English).
Material safety data sheets
To view Material Safety Data Sheets (MSDS), go to http://www.hp.com/go/msds (in English).
Ozone production
This product generates no appreciable ozone gas (O3).
Paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309 and EN 12281:2002. Plastic parts over 25 grams (0.88 ounces) are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of product life.
Recycling program
HP offers an increasing number of product return and recycling programs in many countries and regions, and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. For more information about the recycling of HP products, go to www.hp.com/go/recycle (in English).
Regulatory specifications
The following sections contain information about the product and regulatory specifications.
Regulatory model number
For regulatory identification purposes, your product is assigned a Regulatory Model Number. The Regulatory Model Number for your product is SNPRC-0803 (HP Officejet 7000 Printer). This regulatory number should not be confused with the marketing name (HP Officejet 7000 Printer Series) or product number.
Exposure to radio frequency radiation
The radiated output power of this device is far below the FCC radio frequency exposure limits. Nevertheless, the device shall be used in such a manner that the potential for human contact during normal operation is minimized. This product and any attached external antenna, if supported, shall be placed in such a manner to minimize the potential for human contact during normal operation. In order to avoid the possibility of exceeding the FCC radio frequency exposure limits, human proximity to the antenna shall not be less than 20 cm (8 inches) during normal operation.
