Document ID: c01758071
Version: 1
HP EliteBook 2530p Notebook PC System BIOS Update F.0B
Release date : 29-May-2009
Last updated : 02-Jun-2009
DETAILS OF CHANGE
  • Added an F10 setup option to disable USB devices that makes the computer exit Standby.
  • Added an F10 setup option to enable/disable the system audio codec.
  • Updated the brightness table to support new display panels.
  • Updated Intel Memory Reference Code (MRC) to version 2.7, which fixes the issue where the Mobile Intel 4 Series Express Chipset may stop responding (system hang) during a warm reboot.
  • Fixed an intermittent issue where the Bluetooth device and the WLAN device cannot be powered on or off simultaneously.
  • Fixed an issue where certain USB CD drives are unable to support bootable CD media.
  • Fixed an issue where DriveLock cannot be set in the Swedish language environment.
REASON FOR CHANGE
To implement changes under "Details of Change."
IMPACT OF CHANGE
None
Components affected:
DATE OF CHANGE
Effective date : 17-Jul-2009
Hardware platforms affected : HP EliteBook 2530p Notebook PC
