HP Designjet 4020 and 4520 Printer Series - Change the front panel contrast
To change the contrast of the front panel display, select the icon, then Printer configuration > Front panel options > Select display contrast, and choose a value using the Up or Down key. Press the Select key to set the value you have chosen.
