HP Designjet T1120 SD MFP Product Series - Install New System Software
A new software version for your system can be supplied in the following manners:
  • On a USB flash memory
  • Through a network PC – internet download, CD-ROM, other.
To install a new software version from a USB flash memory
  1. Press Options > Advanced Options > Software Update to start the Software Update & Recovery Mode menu.
  2. Insert the USB flash memory into the USB port on the side of the touch screen.
  3. Choose the System Update/Recover option in the Software Update & Recovery Mode menu.
  4. The new program version image will appear in the program version image list. It can be identified by the text “USB” in the list.
  5. Select this image to install it.
  6. Select the Return to normal scanner operation button and confirm. The system will load and initialize all its parameters. DO NOT TURN OFF THE SCANNER OR INTERUPT THE LOAD PROCESS. THIS STEP CAN TAKE UP TO 10 MINUTES TO COMPLETE.
  7. At the end of the system load process, you will be asked to calibrate the touch screen. Press the arrows and OK button when prompted.
  8. Select the language for your system software.
  9. Accept the HP license agreement.
  10. Your system will complete the recovery process and start up your scan and copy program interface.
To install a new software version from a PC, the following requirements must apply:
  1. Your scan/copy system must be connected and setup (recognized) on the local network.
  2. You need access to a PC that is set up on the network.
  3. A browser must be installed on the PC.
To install from the CD-ROM:
  1. Write down your scan/copy system’s IP address. The IP address can be seen through the Options > Advanced Options > Network dialog.
  2. Save the new software installation file on the PC; either from an inserted CD-ROM, or download from the internet.
  3. Open a web browser on the PC and enter the scan/copy system IP in the address field. This will open the scan/copy system's network accessed Upgrading Scanner Software interface.
  4. Use the browse option to locate and select the installation file on the CD-ROM.
  5. Install the software. This will upload the software to your scan/copy system. When done you can shut down the PC. The remaining steps take place at the scan/copy system touch screen.
  6. Press Options > Advanced Options > Software Update to start the Software Update & Recovery menu.
  7. Choose the System Update/Recover option in the Software Update & Recovery menu.
  8. The new program version image you uploaded from the CD-ROM will appear in the program version image list.
  9. Select this image to install it.
  10. Select the Return to normal scanner operation button and confirm. The system will load and initialize all its parameters. DO NOT TURN OFF THE SCANNER OR INTERUPT THE LOAD PROCESS. THIS STEP CAN TAKE UP TO 10 MINUTES TO COMPLETE.
  11. At the end of the system load process, you will be asked to calibrate the touch screen. Press the arrows and OK button when prompted.
  12. Select the language for your system software.
  13. Accept the HP license agreement.
  14. Your system will complete the recovery process and start up your scan and copy program interface.
Country: Flag Vietnam
