    Windows 11 Upgrade Guide
HP Designjet T1120 Printer Series - Printer specifications
Functional specifications
HP 72 ink supplies
Printheads
Two inks in each printhead: gray and photo black, matte black and yellow, and magenta and cyan
Ink cartridges
Cartridges containing 69 ml of ink: gray, photo black, yellow, magenta, and cyan
Cartridges containing 130 ml of ink: gray, photo black, matte black, yellow, magenta, and cyan
Paper sizes
Minimum
Maximum
Roll Width
11 inches (279 mm)
24-inch printer: 24 inches (609 mm)
44-inch printer: 44 inches (1118 mm)
Roll Length
300 feet (91.4 m)
Sheet Width
8.3 inches (210 mm, A4 Portrait)
Sheet Length
11 inches (279 mm, Letter Portrait)
24-inch printer: 36 inches (915 mm)
44-inch printer: 66 inches (1676.4 mm)
Printing resolutions
Print-quality
Maximum detail
Drive
Rendering Resolution (ppi)
Printing Resolution (dpi)
Best
On
Off
Any
Any
1200 × 1200
1200 × 1200
600 × 600
2400 × 1200 (glossy paper only)
1200 × 1200 (any other paper type)
600 × 600
Normal
On
Off
Any
HP-GL/2
PostScript
600 × 600
600 × 600
300 × 300
600 × 600
600 × 600
600 × 600
Fast
On
Off
Any
HP-GL/2
PostScript
600 × 600
600 × 600 (1)
300 × 300
600 × 600
600 × 600 (2)
600 × 600 (2)
*For a list of supported glossy paper, see Order paper.
Margins
Top right and left margins
5 mm = 0.2 inches
Bottom margin (trailing edge)
5 mm = 0.2 inches (roll)
17 mm = 0.67 inches (sheet)
Mechanical accuracy
±0.1% of the specified vector length or ±0.1 mm (whichever is greater) at 23°C (73°F),  50-60% relative humidity, on E/A0 printing material in Best or Normal mode with HP Matte Film roll feed.
Graphic languages supported
HP PCL3 GUI, HP GL/2 RTL, CALS/G4, PDF (HP Designjet T1120ps only), PostScript (HP Designjet T1120ps only), TIFF (HP Designjet T1120ps only), JPEG (HP Designjet T1120ps only)
Physical specifications
Printer physical specifications
24-inch printer
24-inch printer (without stand)
44-inch printer
143 lb (65 kg)
103.6 lb (47 kg)
189 lb (86 kg)
Width
49.7 inches (1262 mm)
69.7 inches (1770 mm)
Depth
Minimum: 26 inches (661 mm)
Maximum: 28.8 inches (732 mm)
Height
41.2 inches (1047 mm)
15.4 inches (391 mm)
Memory specifications
HP Designjet T1120 Memory (DRAM) supplied
384 MB
HP Designjet T1120ps Memory (DRAM) supplied
320 MB
Hard disk
80 GB
Power specifications
Printer power specifications
Source
100–240 V ac ±10%, auto-ranging
Frequency
50–60 Hz
Current
< 2 A
Consumption
< 200 W
Ecological specifications
This product complies with European Union WEEE and RoHS Directives. To determine the ENERGY STAR qualification status of these product models, please go to http://www.hp.com/go/energystar.
For the up-to-date ecological specifications of your printer, please go to http://www.hp.com/ and search for “ecological specifications”.
Environmental specifications
Printer environmental specifications
Temperature range
Humidity range
Operating for optimal print-quality
22°C to 26°C (72°F to 79°F)
30% to 60%
Operating for standard printing
15°C to 35°C (59°F to 95°F)
20% to 80%
Printer without consumables
5°C to 40°C (41°F to 104°F)
Non-operating packed consumables and printer:
-40°C to 60°C (-40°F to 140°F)
Acoustic specifications
Printer acoustic specifications (declared according to ISO 9296).
Idle sound power level
4.4 B (A)
Operating sound power level
6.9 B (A)
Idle sound pressure at bystander
29 dB (A)
Operating sound pressure at bystander
57 dB (A)
