    Windows 11 Upgrade Guide
HP Compaq t5135 Thin Client - How to Get Administrator Login Prompt
Issue
By default, the HP Compaq t5135 Thin Client boots to a user login.
Solution
To login as administrator on the thin client, restart the thin client and keep tapping the left SHIFT key until you get the login prompt. At the login prompt, type the user name as Administrator and the password as admin.
