HP t5135 and t5145 Thin Client - Information on Default Root Certificates for SSL and TLS Communication
In ICA connection configuration using SSL or TLS to locate the Citrix farm, a root certificate is required on the client device that can verify the signature of the Certificate Authority on the server certificate.
Details
The following table lists the default root certificates built into the t5135 and t5145 image:
Certificate
Issuing Authority
Class4PCA_G2_v2.crt
VeriSign Trust Network
Class3PCA_G2_v2.crt
BTCTRoot.crt
Baltimore Cyber Trust Root
GTECTGlobalRoot.crt
GTE Cyber Trust Global Root
Pcs3ss_v4.crt
Class 3 Public Primary Certification Authority
SecureServer.crt
Secure Server Certification Authority
It is not required to obtain and install root certificates on the client device to use the certificates from these Certificate Authorities
t5135 and t5145 image is a locked down model hence adding a self signed root certificate to the client is not an option.
Country: Flag Vietnam
