HP Pavilion 2159v Monitor - Product Specifications
The HP Pavilion 2159v is a 21.5-inch wide-screen monitor with liquid crystal display (LCD) and thin-film transistor (TFT) screen.
Figure : Photo of the HP Pavilion 2159v LCD wide-screen monitor
FV586AA
Features
The HP Pavilion 2159v LCD wide-screen monitor has the following features:
  • 1920 x 1080 factory-set resolution
  • Supports VGA video input connector
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
Technical specifications
LCD feature
Specification
Display size
21.5-inch (54.61 cm) diagonal and viewable image
Panel active area (width x height): 18.77-inch x 10.56-inch (47.67 cm x 26.82 cm)
Display type
Thin-Film Transistor LCD active matrix
Input terminal
1 VGA connector
Integrated speakers
2 watts per speaker
Scanning frequency
Horizontal scan range 24-94 KHz
Vertical scan range 50-76 Hz
Viewing angle
Horizontal viewing angle: 160 degrees
Vertical viewing angle: 160 degrees
Recommended resolution (H x V)
1920 x 1080 @ 60Hz
Contrast ratio
Up to 1000:1
Response time
5 ms (typical)
Pixel pitch
0.248 mm
Power source - AC/DC adapter
Input rating: 100 to 240V~
frequency: 50~60Hz
Power consumption: 45 watts maximum power consumption in operating mode, <2 W in sleep mode
Operating environment
Temperature: 41 degrees F to 105 degrees F (5 degrees C to 40 degrees C )
Humidity: 20% RH through 80% RH (non-condensing)
Storage environment
Temperature: -29 degrees F to 140 degrees F (-20 degrees C to 60 degrees C)
Humidity: 5% RH through 95% RH (non-condensing)
Dimensions
H x W x D (unpacked):
15.4 x 21 x 7.8 inches (39.1 x 53.3 x 19.8 cm)
Unpacked: 12.3 lbs (5.58 Kg)
EMI standard
FCC Class B
Mounting
Standard VESA 4-hole 100 mm x 100 mm
