Blinking Lights on the HP Officejet 4400 (K410), Deskjet Ink Advantage (K209), and Deskjet F4400 All-in-One Printer Series
Blinking Lights
The following sections describe the most common blinking lights combinations that display on the printer control panel, followed by solutions for each combination. Find the blinking lights pattern you are experiencing, and then follow the steps to resolve the issue.
    Figure : Control panel with the potential blinking lights indicated
    Image: Control panel with the potential blinking lights indicated
  1. Power button light
  2. Estimated Ink Level lights
  3. Number of Copies display (where an 'E' might appear)
  4. Attention light
There might be more than one solution for some blinking lights patterns. After you find the pattern that matches your blinking lights pattern, try each solution to resolve the issue.
Country: Flag Vietnam
