    Fix HP Printer issue on macOS
HP LaserJet 4200/4250/4300/4350 Printer Series - How to Replace Fuser
This document describes fuser removal and replacement for the HP LaserJet 4200/4250/4300/4350 printer series.
Details
  warning:
The fuser might be very hot. After turning off the printer power, allow the fuser to cool for at least 30 minutes before removing it.
  1. Remove the rear output bin.
    To remove the rear output bin, complete the following steps:
    1. Open the rear output bin.
      If the duplexer is installed, lift it up slightly and pull it away from the printer to remove it.
    2. Squeeze the hinge pin out of its mounting hole.
    3. Rotate the output bin away from the printer until the right hinge pin is released, and then remove the output bin.
  2. Squeeze the blue fuser-release tabs.
  3. Pull the fuser straight back and out of the printer.
    Do not drop or jar the fuser. It can easily be damaged if it is mishandled.
    Hint: When you replace the fuser, make sure that it is fully seated into the printer. You should hear both sides snap into place.
