Features
Chassis Dimensions (HxWxD)
15.14 x 7.27 x 16.36 inches
385 x 185 x 416 mm.
Temperature
Operating: 50 degree to 95 degree F (10 degree to 35 degree C) at sea level
with an altitude de-rating of 1.0 degree C per every
1000 ft (300 m) above sea level to a
maximum of 10000 ft (3048 m), no direct
sustained sunlight. Maximum rate of change
is 50 degree F/Hr (10 degree C/Hr). The upper limit may
be limited by the type and number of options
installed..
Storage: –22 degree to 140 degree F (–30 degree to 60 degree C).
Humidity
Operating: 10% to 90% relative humidity (Rh),
35 degree C maximum wet bulb temperature, noncondensing.
Storage: 10% to 90% relative humidity (Rh),
Altitude
Operating: 0 to 10,000 feet (0 to 3048 meters) –
This value may be limited by the type and
number of options installed. Maximum
allowable altitude change rate is 1,000
ft/min (304.8 m/min).
Non-Operating: 0 to 30,000 feet (0 to 9,144 meters) –
Maximum allowable altitude change rate is
1200 ft/min (365.76 m/min).
System weight
18.4 lb (8.34 kg).
Power
250 W Power Supply – PFC PFC HV immunity (410V/s) with a
115/230v line switch.
Security
- ${title}
- ${title}
hp-hero-support-search
- ${title}
- ${title}
- ${title}
HP Compaq dx2810 Small Form Factor PC - Specifications
Hardware Specifications
Communications
Features
Communication
Wireless LAN:
NIC: Intel Pro 1000 PT Gb Ethernet PCIe NIC.
Graphics
Modem
LSI PCIe x1 56K International SoftModem.
Audio
Features
Audio
- ${title}
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
