    We are upgrading our website
HP gt7725 Thin Client - Specifications
Physical specifications
Feature
Dimensions (h x w x d) (approximate)
Without stand:
  • 254.5 x 45.7 x 215.14 mm (10.0 x 1.8 x 8.47 in)
With stand:
  • 266.7 x 45.7 x 215.14 mm (10.5 x 1.8 x 8.47 in)
With expansion module (quad):
  • 254.5 x 76.2 x 215.14 mm (10.0 x 3.0 x 8.47 in)
Weight (approximate)
With stand:
  • 1.6 kg (3.5 lb)
  • 2.2 kg (4.8 lb)
Technical specifications
Feature
Operating voltage range
  • 100 to 240 V AC
Rated line frequency
  • 50 to 60 Hz
Power output (maximum)
  • 120 W
Rated output current (maximum)
  • 6.15 A
Output voltage
  • +19 V DC
Power consumption
  • Idle power: 41 W, dual; 61 W, quad1
1: The actual power consumption at the user's location could vary and is dependent on many factors including but not limited to software load on the thin client, number of attached monitors and peripherals, and environmental factors.
Feature
Server operating system compatibility
  • Citrix XenApp 4.5 and 5.0
  • Citrix XenDesktop 3 and 4
  • Citrix Presentation Server 4.0 and 4.5
  • Windows Server 2008/2008 R2 Remote Desktop Services
  • Windows 2000/2003 Terminal Server families
  • Unix/Linux Servers Linux Enterprise Server 11 (XDMCP/X.11 for X Windows)
  • Mainframes and Mid-Range Servers
Citrix and Microsoft support
  • Citrix ICA 11.111
  • RDesktop 1.6 (RDP 6 client)
Security
  • Secure USB compartment with 2 USB 2.0 ports
  • Security lock slot (cable lock sold separately)
  • Smartcard support via PCSC Lite Framework and CCID Driver
  • User and Administrator logins for greater content control
  • Read-only operating system
  • Stateless security mode (requires quick and easy setup to enable)
Environmental specifications
Features
Temperature range
Operating:
  • 10° to 35°C (50° to 95°F)
With expansion module or mounted with HP Quick Release:
Non-operating:
  • -30° to +60°C (-22° to +140°F)
Humidity
  • 20% to 80% condensing
  • 10% to 90% non-condensing
Cooling
  • Active
Regulatory compliance
Feature
Ergonomics
  • The product has been tested and found to comply with all applicable GS ergonomic requirements.
Safety
  • International: IEC 60950-1, 12:2005, with CB certificate and all national deviations
    US and Canada: UL 60950-1 / CAN/CSA 22.2 No. 60950-1-03, 07:2006, Bi-National Standard for ITE Safety in the US and Canada and is published jointly by UL and CSA.
    Europe: EN 60950-1, 06:2003, Information Technology Equipment
EMC
  • FCC Class B; CE Mark; EN55022 B; EN55024; BMSI, KCC, CCC, C-Tick, and VCCI
Country: Flag Vietnam
