    Fix Windows 10 Update Issues
HP EliteBook 8530p Notebook PC - Removing and Replacing the Fan
This document is provided to assist in removing and replacing the Fan for the HP EliteBook 8530p Notebook PC.
Minimum skill level
Tools required
T8-7mm screwdriver
Parts required
The replacement part number will vary depending on the Fan that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Fan assembly
495079-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Fan, click on the link below. Or use the product video listing on the HP Services Media Library, then select Fan from the menu on the upper left hand side of the screen.
Click here to view the Fan removal video (Right-click on the video link above to open in a new window/tab).
Fan removal
  2. note:
    On the extreme edition, the fan exhaust opening is wider than on the non-extreme edition. Otherwise, the removal and replacement procedures are the same for both editions. Be sure to order and install the fan for the appropriate edition.
  3. Disconnect the fan cable from the system board.
  4. Remove the three T8-7mm screws that secure the fan to the base enclosure.
  5. Lift and remove the fan.
Fan replacement
  1. Toe the fan into the base enclosure.
  2. Replace the three T8-7mm screws that secure the fan to the base enclosure.
  3. Reconnect the fan cable to the system board.
Parts return
