    Fix Windows 10 Update Issues
HP EliteBook 8530p Notebook PC - Removing and Replacing the Keyboard
This document is provided to assist in removing and replacing the Keyboard for the HP EliteBook 8530p Notebook PC.
Minimum skill level
Tools required
P1 Phillips-head screwdriver
Parts required
The replacement part number will vary depending on the Keyboard that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Keyboard with pointing stick - 12.3-inch keyboard with durable key cap coating - Includes pointing stick and pointing stick cable
495042-xx1 (Original)
No
The part number will vary based on the country. Click here for a list of country specific spare part numbers.
Summary of instructions
To view a video demonstrating the procedure for removing the Keyboard, click on the link below. Or use the product video listing on the HP Services Media Library, then select Keyboard from the menu on the upper left hand side of the screen.
Click here to view the Keyboard removal video (Right-click on the video link above to open in a new window/tab).
Keyboard removal
  2. Loosen the two captive, spring-loaded P1 Phillips-head screws that secure the keyboard to the base enclosure.
    The screw locations are marked by keyboard icons on the memory/wireless WAN Minicard cover.
  3. Turn the notebook right side up and open the display panel fully.
  4. Slide the four plastic locking tabs toward the bottom edge of the keyboard to unlock the keyboard from the switch cover.
  5. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and then rotate it upside down on the top cover.
    Use care to prevent damaging the keyboard ribbon cable. There is minimal slack in the keyboard ribbon cable.
  6. Using minimal force, lift the locking bar to unlock the keyboard ZIF connector on the system board.
    Use care to prevent damaging the ZIF connector and ribbon cable.
  7. Remove the keyboard ribbon cable from the ZIF connector.
  8. Using minimal force, lift the locking bar to unlock the pointing stick ZIF connector on the system board.
  9. Remove the pointing stick ribbon cable from the ZIF connector.
  10. Remove the keyboard.
Keyboard replacement
  1. Place the keyboard upside down on the top cover.
  2. Insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
  3. Push the locking bar down to lock the keyboard ZIF connector on the system board.
  4. Insert the pointing stick ribbon cable into the pointing stick ZIF connector on the system board.
    Use care to prevent damaging the pointing stick ribbon cable.
  5. Push the locking bar down to lock the pointing stick ZIF connector on the system board.
  6. Toe the tabs on the bottom edge of the keyboard into the top cover.
  7. Press the keyboard flat and slide the four plastic locking tabs toward the rear of the notebook to lock the keyboard to the switch cover.
  8. Close the display panel and turn the notebook upside down.
  9. Tighten the two captive, spring-loaded P1 Phillips-head screws that secure the keyboard to the base enclosure.
Parts return
