    Fix Windows 10 Update Issues
HP EliteBook 8530p Notebook PC - Removing and Replacing the RTC Battery
This document is provided to assist in removing and replacing the RTC battery for the HP EliteBook 8530p Notebook PC.
Minimum skill level
Tools required
P1 Phillips-head screwdriver
Parts required
The replacement part number will vary depending on the RTC battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Real Time Clock (RTC) Battery
501115-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the RTC battery, click on the link below. Or use the product video listing on the HP Services Media Library, then select Real-Time Clock Battery from the menu on the upper left hand side of the screen.
Click here to view the RTC battery removal video (Right-click on the video link above to open in a new window/tab).
RTC battery removal
  2. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless WAN Minicard cover to the bottom of the notebook.
  3. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless WAN Minicard cover and remove it.
  4. Disconnect the RTC battery cable from the system board.
  5. Slide the RTC battery out of the sleeve on the system board.
RTC battery replacement
  1. Insert and the RTC battery into the sleeve on the system board.
  2. Reconnect the RTC battery cable to the system board.
  3. Toe the memory/wireless WAN Minicard cover into the enclosure.
  4. Press down around the edges until the cover snaps into place.
  5. Tighten the two captive P1 Phillips-head screws.
Parts return
