    Fix Windows 10 Update Issues
HP EliteBook 8530p Notebook PC - Removing and Replacing the Memory Boards
This document is provided to assist in removing and replacing the Memory boards for the HP EliteBook 8530p Notebook PC.
Minimum skill level
Tools required
P1 Phillips-head screwdriver
Parts required
The replacement part number will vary depending on the Memory boards that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
1 GB, 800 MHz, CL=6 PC2-6400, DDR2 SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
495052-001 (Modified)
Yes
2 GB, 800 MHz, CL=6 PC2-6400, DDR2 SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
495053-001 (Modified)
Yes
4 GB, 800 MHz, CL=6 PC2-6400, DDR2 SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
495054-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Memory boards, click on the link below. Or use the product video listing on the HP Services Media Library, then select Memory boards from the menu on the upper left hand side of the screen.
Click here to view the Memory boards removal video (Right-click on the video link above to open in a new window/tab).
  2. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless WAN Minicard cover to the bottom of the notebook.
  3. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless WAN Minicard cover and remove it.
  4. Push both arms outward simultaneously to release the memory board to the spring tension position.
    When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  5. Grasp the memory board by the edges and pull gently to remove it.
  6. Place the memory board in a static dissipative bag.
  7. Repeat for the other memory board.
Memory boards replacement
  1. Remove the memory board from the static dissipative bag.
  2. Locate the alignment slot and align it to the empty board receptacle.
  3. Grasp the expansion memory board by the edges and push gently to replace it.
  4. Press the memory board down to latch the arms.
  5. Repeat for the other memory board.
  6. Toe the memory/wireless WAN Minicard cover into the enclosure.
  7. Press down around the edges until the cover snaps into place.
  8. Tighten the two captive P1 Phillips-head screws.
Parts return
