    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP EliteBook 8530p Notebook PC - Removing and Replacing the Battery
This document is provided to assist in removing and replacing the Battery for the HP EliteBook 8530p Notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the Battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
8-cell, 2.55-Ah (73-Wh) Li-ion battery
501114-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Battery, click on the link below. Or use the product video listing on the HP Services Media Library, then select Battery from the menu on the upper left hand side of the screen.
Click here to view the Battery removal video (Right-click on the video link above to open in a new window/tab).
Battery removal
  2. Slide the battery release latch to the release position to partially eject the battery.
  3. Slide the battery out of the battery bay.
Battery replacement
  1. Slide the battery into the battery bay until it is properly seated and the release latch clicks.
Parts return
