HP EliteBook 6930p Notebook PC - Removing and Replacing the Keyboard
This document is provided to assist in removing and replacing the Keyboard for the HP EliteBook 6930p Notebook PC.
Minimum skill level
Tools required
  • Small, Phillips-head P0 screwdriver
  • Small, flat-bladed screwdriver or a flat-bladed alignment tool
Parts required
The replacement part number will vary depending on the Keyboard that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
For use in Belgium
483010-A41 (Modified)
No
For use in Brazil
483010-201 (Modified)
No
For use in the Czech Republic
483010-221 (Modified)
No
For use in Denmark
483010-081 (Modified)
No
For use in Europe, the Middle East, and Africa
483010-021 (Modified)
No
For use in France
483010-051 (Modified)
No
For use in French Canada
483010-121 (Modified)
No
For use in Germany
483010-041 (Modified)
No
For use in Greece
483010-DJ1 (Modified)
No
For use in Hungary
483010-211 (Modified)
No
For use in Iceland
483010-DD1 (Modified)
No
For use in Israel
483010-BB1 (Modified)
No
For use in Italy
483010-061 (Modified)
No
For use in Japan
483010-291 (Modified)
No
For use in Latin America
483010-161 (Modified)
No
For use in the Netherlands
483010-B31 (Modified)
No
For use in Norway
483010-091 (Modified)
No
For use in Portugal
483010-131 (Modified)
No
For use in Russia
483010-251 (Modified)
No
For use in Saudi Arabia
483010-171 (Modified)
No
For use in Sweden and Finland
483010-B71 (Modified)
No
For use in Slovakia
483010-231 (Modified)
No
For use in Slovenia
483010-BA1 (Modified)
No
For use in South Korea
483010-AD1 (Modified)
No
For use in Spain
483010-071 (Modified)
No
For use in Switzerland
483010-BG1 (Modified)
No
For use in Taiwan
483010-AB1 (Modified)
No
For use in Turkey
483010-141 (Modified)
No
For use in the United Kingdom
483010-031 (Modified)
No
For use in the United States
483010-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Keyboard, click on the link below. Or use the product video listing on the HP Services Media Library then select Keyboard from the menu on the upper left hand side of the screen.
Click here to view the Keyboard removal video (right-click on the link to open in a new window/tab).
Keyboard removal
  2. Loosen the three captive, spring-loaded P1 Phillips-head screws that secure the keyboard to the base enclosure.
  3. Turn the notebook right side up and open the display panel fully.
  4. Slide the four plastic locking tabs toward the bottom edge of the keyboard to unlock the keyboard from the switch cover.
  5. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and then place it upside down on the top cover.
  6. Using minimal force, lift the locking bar to unlock the keyboard ZIF connector on the system board.
    Use care to prevent damaging the ZIF connector and ribbon cable.
  7. Remove the keyboard ribbon cable from the ZIF connector.
  8. Using minimal force, lift the locking bar to unlock the pointing stick ZIF connector on the system board.
  9. Remove the pointing stick ribbon cable from the ZIF connector.
  10. Remove the keyboard.
Keyboard replacement
  1. Place the keyboard upside down on the top cover.
  2. Insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Use care to prevent damaging the keyboard ribbon cable.
  3. Push the locking bar down to lock the keyboard ZIF connector on the system board.
  4. Insert the pointing stick ribbon cable into the pointing stick ZIF connector on the system board.
    Use care to prevent damaging the pointing stick ribbon cable.
  5. Push the locking bar down to lock the pointing stick ZIF connector on the system board.
  6. Toe the tabs on the bottom edge of the keyboard into the top cover.
  7. Press the keyboard flat and slide the four plastic locking tabs toward the rear of the notebook to lock the keyboard to the switch cover.
  8. Close the display panel and turn the notebook upside down.
  9. Tighten the three captive, spring-loaded P1 Phillips-head screws that secure the keyboard to the base enclosure.
Parts return
