HP Compaq dc5800 Microtower PC - Removing and Replacing the Front Bezel
This document is provided to assist in removing and replacing the Front Bezel for the HP Compaq dc5800 Microtower PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the Front Bezel that is being replaced. If a part is listed as 'Yes' under 'Requires Return' then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Front Bezel
460883-001
No
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the Front Bezel, click on the link below. Or use the product video listing on the HP Services Media Library, then select Front Bezel from the menu on the upper left hand side of the screen.
Click here to view the Front Bezel removal video (right-click on the link to open in a new window/tab).
Front Bezel removal
  2. Pull up on the two release tabs to partially disengage the front bezel.
  3. Pull the front bezel away from the chassis until the bottom tab releases.
  4. Continue to rotate the front bezel away from the chassis and remove it.
Front Bezel replacement
  1. Insert the two hinge tabs on the end of the front bezel into the slots on the chassis.
  2. Rotate the front bezel against the chassis.
  3. Press the front bezel against the chassis until the release tabs snap into the chassis slots.
Country: Flag Vietnam
