HP Compaq t5530 Thin Client Specifications
Product description
The HP Compaq t5530 Thin Client delivers a great desktop experience for general office applications. This unit's enhanced features make it ideal for mainstream business use, with support for legacy ports, ICA, RDP, terminal emulation, Windows Media Player, and basic web browsing. The HP t5530 can provide convenient access to server-based computing solutions, HP’s Consolidated Client Infrastructure (CCI), or a variety of remote desktop solutions. HP thin clients lead the way with proven business technology for maximum security and lower ownership costs, and are easy to buy, deploy, and manage with a great price-performance ratio.
Product Features
Feature
Specification
Processor
Via Eden 800 MHz
System memory
128 MB (16 MB reserved for video)
Flash memory
64 MB
Video
16 MB UMA shared video memory. Maximum video resolution is 1600x1200, 32 bit @ 60 Hz
USB ports
8 – USB 2.0 (2 in front, 4 in back, 2 in secure compartment to prevent theft)
Serial/parallel ports
1 serial and 1 parallel
PS/2 ports
2 PS/2
Audio
  • Mic In/Headphone Out (ports in front)
  • Internally amplified speaker, full 16-bit stereo, 44 KHz sample rate
Networking
  • TCP/IP with DNS and DHCP support
  • 10/100 BaseT Fast Ethernet, twisted pair (RJ-45)
  • Direct Connection through RS232, Point-to-Point Protocol (POP), Point-to-Point over Ethernet (PPPoE)
  • VPN connection through Microsoft Point-to-Point Tunneling Protocol (PPTP), Layer 2 Tunneling Protocol (L2TP)
  • FTP/DHCP for automatic updates
  • Supports Citrix load balancing on ICA
  • Simple Network Time Protocol (SNTP)
  • Microsoft SMB for deploying image from PC that has been defined as a shared resource
  • Wake on LAN
  • PXE
Session allocation manager/session brokers
  • HP PC SAM Software for access to HP’s Consolidated Client Infrastructure (CCI)
  • Citrix Desktop Broker for access to Virtual Desktop Infrastructure (VDI)
Server OS compatibility/support
  • Citrix Presentation Server 4.0 including the Desktop Broker feature
  • Citrix Metaframe Presentation Server 3.0, Citrix Metaframe XP Presentation Server
  • Citrix Metaframe 1.x
  • Windows 2000/2003 Server families
  • Windows 2000/2003 Server Terminal Services
  • Windows 2000 Advanced Server, Windows 2000 Advance Server Terminal Services
  • Microsoft Windows NT 4.0 Server
  • Windows NT 4.0 Terminal Server Edition
  • VMware Virtual Desktop Infrastructure (RDP)
Security features
  • Smart card support for two-factor authentication for secure access to network
  • Locked down admin and user passwords
  • Remote BIOS configurability to lock down ports
  • Selectively disable USB ports
Manageability and deployment
  • System manageable through Altiris Deployment Solution
  • Make changes to image/settings on "master" thin client, then deploy to “target” clients
  • Support for HP OpenView CCM4
  • FTP/DHCP image update feature
Accessories
  • USB wireless: HP4050
  • Kensington lock: PC766A
  • HP Quick Release: EM870AA
  • AC adapter: DZ991A
Dimensions
18.57 x 18.57 x 5.24 cm
(7.31 x 7.31 x 2.06 in) – without stand
Stand adds 1.9 cm (0.75 in) to height.
1.3 kg (2.9 lbs) – without stand
Stand weighs 30 g (~1 oz)
Limited 3-year hardware warranty
System specifications
Feature
Processor
VIA Eden 800 MHz
Chipsets
Northbridge: VIA CN700; Southbridge: VIA VT8237
Memory
  • Flash 64 MB
  • System Memory 128 MB (16 MB reserved for video)
Component specifications
Feature
Input/Output/ Peripheral Support
  • Keyboard: USB or PS/2 (both supported) Keyboard included with every thin client. Type of included keyboard (USB or PS/2) varies by region.
  • Mouse: USB or PS/2 (both supported) Mouse included with every thin client. Type of included mouse (USB or PS/2) varies by region.
  • Printer: Local (ThinPrint .print TCP Client) and/or network printers (RDP, ICA, LPD, JetCET)
  • Video: VGA-type video output (DB-15)
Audio
  • Output: Internal amplified speaker, 1/8-inch mini, full 16-bit stereo, 44-kHz sample rate
  • Input: 1/8-inch mini microphone
Security
Security lock slot (cable lock sold separately)
I/O ports and connectors
8 USB 2.0 ports , 1 Serial, 1 Parallel, 2 PS/2 connectors
Networking
  • TCP/IP with Dynamic DNS and DHCP support
  • Direct connection via RS-232, Point-to-Point Protocol (PPP), Point-to-Point over Ethernet (PPPoE) VPN connection via MS Point-to-Point Tunneling Protocol (PPTP), Layer-2 Tunneling Protocol (L2TP)
  • DHCP with FTP option for automatic updates
  • Microsoft SMB (Server Message Block) for deploying image from a PC that has been defined as a shared resource (No need to set up FTP Server, if this option is used)
  • Wake on LAN
  • PXE
Graphics specifications
Mode
Refresh Rates
Color Depth
800 x 600
60, 75, or 85 Hz
8, 16, or 32 bit
1024 x 768
60, 75, or 85 Hz
8, 16, or 32 bit
1280 x 1024
60, 75, or 85 Hz
8, 16, or 32 bit
1600 x 1200
60, 75, or 85 Hz
8, 16, or 32 bit
1600 x 1200
60 Hz
32 bit
1440 x 900
60 Hz
16 or 32 bit
1680 x 1050
60, 75, or 85 Hz
16 or 32 bit
Electrical specifications
Feature
Power
Worldwide auto-sensing 100 to 240 VAC, 50 to 60 Hz Average power consumption of this thin client in a typical setup is 14.0 W.
Physical specifications
Feature
Dimensions (H x W x D)
  • Without stand: 18.57 x 18.57 x 5.24 cm (7.31 x 7.31 x 2.06 in)
  • Stand only: Height - 1.9 cm (0.75 in)
Weight (approximate)
  • With stand: 1.3 kg (2.9 lbs)
  • Stand only: 30 g (~1 oz)
Software/OS
Feature
Specification
Operating System
Microsoft Windows CE 5.0
Client software
  • Altiris manageability agent (full version)
  • HP ThinConnect with kiosk-mode capability
  • TeemTalk (CE Terminal Emulation software)
  • Citrix ICA 9.x
  • RDP client (version 5.5)
  • Thinprint TCP/IP Client for enhanced local printing
  • JetCET Print Professional
  • Remote control with VNC
Environmental specifications
Feature
Operating temperature range
50° to 104° degree Fahrenheit (10° to 40° degree Celsius)
Non-operating temperature range
–22° to 140° degree Fahrenheit (–30 to 60° degree Celsius)
Humidity
20% to 80% condensing/ 10% to 95% non-condensing
Safety certifications
Feature
Regulatory Compliances
  • Ergonomics: The product has been tested and found to comply with all applicable GS ergonomic requirements.
  • RF Interference: FCC Class B, CE Mark, VCCI
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
