HP iPAQ 110 Classic Handheld - File Transmission via Bluetooth
You can save a file to a particular folder or destination while transferring files via Bluetooth.
Sending files using Bluetooth
Follow these steps to save the file to the particular folder before transmitting the file via Bluetooth.
1. Select Start > Settings > Connections. Tap the Bluetooth icon.
2. Under Bluetooth Settings, tap the Services tab.
3. Select File Transfer > Advanced . Browse the folder.
4. Tap OK.
