    We are upgrading our website
HP Scanjet 8200 Series Scanner - Displays "DMA timeout" Error on Front Panel
Issue
When scanning slides or negatives from the second, third, or fourth positions in the Transparent Media Adapter (TMA), the HP Scanjet 8200 scanner displays a DMA timeout error message on the front panel. You may also get the HP imaging device could not be initialized. An error occurred communicating with the device error message.
Solution
A firmware update (version 1.06, file name COL4534.exe, size 292 KB) is available for the HP Scanjet 8200 scanner which can fix the issue.
Install this update only if you have the previously described issue. After downloading the firmware, double-click the downloaded file and follow the on-screen instructions to flash the firmware. The firmware update works on the following operating systems: Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows ME, Microsoft Windows NT 4.0, and Microsoft Windows XP.
Important: After installing the update, the software will prompt you to shut down the computer. In order for the firmware to be updated, you must allow the computer to shut down. Once the computer is shut down, disconnect the power cable from the scanner. Wait a few moments (10 seconds or more) and then reconnect the power cable to the scanner. Once the power supply is reconnected to the scanner, turn the computer back on.
If you continue to receive the DMA Timeout error message after updating the firmware in your scanner, this may indicate a hardware failure. Contact HP Customer Care for further assistance.
Country: Flag Vietnam
