This product supports printing on special media. Use the following guidelines to obtain satisfactory results. When using special paper or print media, be sure to set the type and size in your print driver to obtain the best print results.
caution:HP LaserJet printers use fusers to bond dry toner particles to the paper in very precise dots. HP laser paper is designed to withstand this extreme heat. Using inkjet paper not designed for this technology could damage your printer.
Media type
Do
Do not
Envelopes
Labels
Transparencies
Letterhead or preprinted forms
Heavy paper
Glossy or coated paper
