HP Designjet Z3200PS Printer Series - Clean the exterior of the printer
Clean the outside of the printer and all other parts of the printer that you regularly touch as part of normal operation with a damp sponge or a soft cloth and a mild household cleaner such as non-abrasive liquid soap.
  warning:
To avoid an electric shock, make sure that the printer is turned off and unplugged before you clean it. Do not let water get inside the printer.
Do not use abrasive cleaners on the printer.
