HP Compaq nx6110 Notebook PC - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the Hard disk drive for the HP Compaq nx6110 Notebook PC.
Minimum skill level
Tools required
P1 Phillips-head screw driver
Parts required
The replacement part number will vary depending on the Hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
30 GB IDE hard drive - 4,200 RPM, 9.5 mm height
378211-001 (Original)
416945-001 (Modified)
Yes
40 GB IDE hard drive - 5,400 RPM, 9.5 mm heigh
380107-001 (Original)
416946-001 (Modified)
Yes
40 GB IDE hard drive - 4,200 RPM, 9.5 mm heigh
378212-001 (Original)
Yes
60 GB IDE hard drive - 4,200 RPM, 9.5 mm height
378213-001 (Original)
416947-001 (Modified)
Yes
60 GB IDE hard drive - 5,400 RPM, 9.5 mm height
378215-001 (Original)
416950-001 (Modified)
Yes
80 GB IDE hard drive - 4,200 RPM, 9.5 mm height
378214-001 (Original)
416948-001 (Modified)
Yes
80 GB IDE hard drive - 5,400 RPM, 9.5 mm height
380108-001 (Original)
416949-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library, then select Hard disk drive from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window/tab.
Hard disk drive removal
  2. Loosen the two captive P1 Phillips-head screws that secure the hard disk drive cover to the bottom of the notebook.
  3. Use your finger or a flat-bladed tool to lift the inside edge of the hard disk drive cover and remove it.
  4. Loosen the captive spring-loaded P1 Phillips-head screw that secures the hard disk drive.
  5. Grasp the Mylar tab and pull the hard disk drive toward the outside edge of the base enclosure to disconnect the hard disk drive from the system board connector.
  6. Lift the hard disk drive out of the bay and remove.
  7. If present, remove the hard disk drive PIN extender. Click here for more information on the PIN extender.
  8. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. If required, replace the hard disk drive PIN extender. Click here for more information on the PIN extender.
  3. Place the hard disk drive into the hard disk drive bay.
  4. Push the hard disk drive toward the inside of the base enclosure until the connector is seated.
  5. Tighten the captive spring-loaded P1 Phillips-head screw that secures the hard disk drive.
  6. Toe the hard disk drive cover into the enclosure.
  7. Tighten the two captive P1 Phillips-head screws.
