HP Compaq nx6110 Notebook PC - Removing and Replacing the Wireless LAN Mini PCI Card
This document is provided to assist in removing and replacing the Wireless LAN Mini PCI card for the HP Compaq nx6110 Notebook PC.
Minimum skill level
Tools required
P1 Phillips-head screw driver
Parts required
The replacement part number will vary depending on the Wireless LAN Mini PCI card that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
802.11b WLAN card, for use in most of the world
381580-001 (Original)
No
802.11b WLAN card, for use in the rest of the world
381581-001 (Original)
No
802.11b/g WLAN card, for use in most of the world
381582-001 (Original)
No
802.11b/g WLAN card, for use in the the rest of the world
381583-001 (Original)
No
802.11b/g combination WLAN card, for use internationally
373032-002 (Original)
No
802.11b/g combination WLAN card, for use Japan
373032-291 (Original)
No
802.11b/g combination WLAN card, for use in the United States
373032-001 (Original)
No
802.11a/b/g combination WLAN card, for use in Europe, Middle East, Africa
373900-021 (Original)
No
802.11a/b/g combination WLAN Mini PCI communications card for use Japan
373900-291 (Original)
No
802.11a/b/g combination WLAN card, for use internationally
373033-002 (Original)
No
802.11a/b/g combination WLAN card, for use Japan
373033-291 (Original)
No
802.11a/b/g combination WLAN card, for use in most of the world
373900-001 (Original)
No
802.11a/b/g combination WLAN card, for use in the United States
373033-001 (Original)
No
802.11a/b/g High Band combination WLAN card
373901-001 (Original)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Wireless LAN Mini PCI card, click on the link below. Or use the product video listing on the HP Services Media Library, then select Wireless LAN Mini PCI card from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window/tab.
Wireless LAN Mini PCI card removal
  2. Loosen the captive P1 Phillips-head screw that secures the memory/Mini PCI cover to the bottom of the notebook.
  3. Use your finger or a flat-bladed tool to lift the outside edge of the memory/Mini PCI cover and remove it.
  4. Carefully disconnect the two wireless antenna cables from the Mini PCI card with a small needlenose pliers or tweezers.
    Use care when disconnecting the wireless antenna cables from the Mini PCI card. Damaged cables or connectors can degrade notebook performance.
  5. Push both arms outward simultaneously to release the Mini PCI card to the spring tension position.
  6. Grasp the Mini PCI card by the edges and pull gently to remove it.
  7. Place the Mini PCI card in a static dissipative bag.
Wireless LAN Mini PCI card replacement
  1. Remove the Mini PCI card from the static dissipative bag.
  2. Locate the alignment slot and align it to the board receptacle.
  3. Grasp the Mini PCI card by the edges and push gently to replace it. Press the Mini PCI card down to latch the arms.
  4. Reconnect the two wireless antenna cables to the Mini PCI card.
    Use care when connecting the wireless antenna cables to the Mini PCI card. Damaged cables or connectors can degrade notebook performance.
  5. Toe the memory/Mini PCI cover into the enclosure.
  6. Tighten the captive P1 Phillips-head screw.
