HP Compaq nx6110 Notebook PC - Removing and Replacing the Battery
This document is provided to assist in removing and replacing the Battery for the HP Compaq nx6110 Notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the Battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Battery (Primary) - 6-cell lithium-ion (Li-Ion), 10.8 VDC, 4.8 Ahr, 52Wh
367457-001 (Original)
No
Battery (Primary) - 6-cell lithium-ion (Li-Ion), 10.8 VDC, 4.8 Ah, 52 Wh
372772-001 (Original)
No
Battery (Primary) - 6-cell lithium-ion (Li-Ion), 10.8 VDC, 4.0 Ah, 43 Wh
383220-001 (Original)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Battery, click on the link below. Or use the product video listing on the HP Services Media Library, then select Battery from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window/tab.
Battery removal
  2. Slide the battery release latch to the release position.
  3. Slide and hold the battery locking latch to the unlocked position.
  4. Slide the battery out of the battery bay.
Battery replacement
  1. Slide the battery into the battery bay until it is properly seated and the locking latch clicks.
Country: Flag Vietnam
