HP ProLiant xw460c Blade Workstation built with HP ProLiant quality and trading-floor proven
reliability, the HP Blade Workstation Solution provides
data centre workstation computing without boundaries.
Feature
Intel 5000P Chipset
Processors
Quad-Core Processor Option Kits:
Dual-Core Processor Option Kits:
note: note: |
Memory
Standard: 2 GB (2 x 1 GB)
Maximum:
64 GB (8 x 8 GB)
note: |
Graphics
Integrated ATI RN-50 1280 x 1024 (32 MB DDR1 memory)
Graphics Adapter
USB Options
Internal USB Support
Internal USB 2.0 connector for security key devices and USB drive keys
Storage Controller
Integrated HP Smart Array E200i RAID controller with 64 MB or 128MB battery-backed write-cache (BBWC).
Internal Drive Support
Up to 2 small form factor (SFF) SAS hot-plug hard disk drives
Network Controller
Features
NVIDIA Quadro FX 560M graphics adapter
Memory size
256 MB
NVIDIA Quadro FX1600M graphics adapter
Memory size
256MB
HP Smart Array E200i Controller
Disk Drive and Enclosure Interface:
3G SAS (Serial Attached SCSI)
Features
Dimensions
Height:
2.207 inches (5.61 cm)
Depth:
20.058 inches (50.95 cm)
Width: 7.154 inches (18.17cm)
Maximum:
14.20 lb (6.44kg)
Temperature
Operating:
50 degree to 95 degree F (10 degree to 35 degree C)
Non-Operating
-40degree to 140 degree F (-40 degree to 60 degree C)
Storage
-4 to 140 degree F (-20 degree to 60 degree C)
Maximum Wet Bulb
Temperature: 86 degree F (-30 degree C)
Relative Humidity
Shipping
10% to 90%
Storage
10% to 95%
Feature
Operating System
