This document provides the prerequisites to install the MIPA-PIN and Mipa license.
- ${title}
- ${title}
- ${title}
- ${title}
HP LaserJet and HP LaserJet MFP Printers - MIPA-PIN and MIPA License Installation Guide
Details
Prerequisites:
1 - MIPA-PIN on a MFP and Mipa on LaserJet with a file system (Hard Disk, DIMM, Compact Flash, or USB) installed.
2 - MIPA-PIN or Mipa Supported Printer (See matrix later in this document).
3 - Printer User Guide with reference to Printer Memory and Expansion.
4 - PC Workstation that can access the Embedded Web Server (Webpage) of the printer.
note:If the MIPA-PIN/Mipa device or software is not installed, please contact HP support if assistance is needed with installing it.
MIPA-PIN/Mipa System Requirements:
MIPA-PIN requires specific versions of HP firmware and HP products, as follows:
HP Color LaserJet 9500mfp or HP LaserJet 9040/9050mfp - version 08.041.8 or later
HP LaserJet 4345mfp - version 09.041.8 or later
HP Color LaserJet 4730mfp - version 46.121.2 or later
note:See the matrix that follows with all information. For products not listed, please contact HP support for assistance in determining if your HP printer is compatible.
Verify if MIPA-PIN/Mipa is being recognized by the printer:
Print a Configuration Page from the front panel of the printer, and look at the second page, which is titled Capella Technologies Firmware Page. Under the Installed Options, you should see the following information:
note:If the Installed Options indicate that it is unlicensed, please contact HP support.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
