Review the following sections for product-specific information.
Figure : HP Color LaserJet CP1514n, CP1515n and CP1518ni Printers
Models and part numbers
HP Color LaserJet models
Part numbers
CC510A
HP Color LaserJet CP1515n
CC377A
HP Color LaserJet CP1518ni
CC378A
System requirements
Component
Windows Computer
Macintosh
Mac OS X v10.2.8 and later
Processor
Pentium II Celeron
PowerPC G3, G4, G5 or Intel Core processor
RAM
Minimum: 512 MB RAM
Minimum: 256 MB RAM
Free disk space
350 MB disk space
150 MB disk space
CD drive
4 x
4 x
Connectivity
Hi-Speed 2.0 USB port
USB: 2.0 Hi-speed compliant cable*
Browser
Your computer must have one of the following browsers installed:
Macintosh OS Safari
Other recommended components
Adobe Acrobat 4.0 or later
* A standard USB cable can be purchased from any reputable dealer.
Physical dimensions
Dimension
Measurement
Height
254 mm (10.0 inches)
Width
399 mm (15.7 inches)
Depth
452 mm (17.8 inches)
18.2 kg (40.02 pounds)
Cartridges
Region
Black cartridge
Cyan cartridge
Magenta cartridge
Yellow cartridge
The Americas
Europe
Middle East and Africa
HP 125A Black
HP 125A Cyan
HP 125A Magenta
HP 125A Yellow
Asia Pacific
HP CB540A
Black
HP CB541A
Cyan
HP CB543A Magenta
HP CB542A Yellow
Paper-handling specifications
The following tables contain specifications for supported paper.
Paper-tray capacities
note:Capacity can vary depending on paper weight and thickness, and environmental conditions.
Type
Capacity Input tray
Capacity Output tray
60 to 90 g/m2 (16 to 24 lb)
125 (20 lb paper)
Up to 200 g/m2 (53 lb)
n/a
Envelopes
90 g/m2 (24 lb)
n/a
Postcards
n/a
Transparency films
Thickness: 0.12 to
0.13 mm (4.7 to 5.1 mils)
n/a
Labels
Thickness: up to 0.23 mm
(9 mils)
n/a
Paper types and sizes
note:The product supports a wide range of standard and custom sizes of paper. Check the printer driver for supported sizes.
Type
Size
Paper
Letter: 216 x 279 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
Executive: 184.2 x 266.7 mm (7.25 x 10.5 inches)
A4: 210 x 297 mm (8.27 x 11.7 inches)
A5: 148 x 210 mm (5.83 x 8.27 inches)
A6: 105 x 148 mm (4.13 x 5.83 inches)
B4: (JIS) 257 x 364 mm (10.12 x 14.33 inches)
B5: (JIS) 182 x 257 mm (7.17 x 10.12 inches)
16k: 197 x 273 mm (7.75 x 10.75 inches)
8.5 x 13: 216 x 330 mm (8.5 x 13 inches)
4 x 6: 107 x 152 mm (4 x 6 inches)
5 x 8: 127 x 203 mm (5 x 8 inches)
10 x 15 cm: 100 x 150 mm (3.9 x 5.9 inches)
Custom: (76 - 216) x (127 - 356) mm ((3 - 8.5) x (5 - 14) inches)
Envelopes
U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
B5: 176 x 250 mm (6.7 x 9.8 inches)
C5: 162 x 229 mm (6.93 x 9.84 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
Monarch: 98 x 191 mm (3.9 x 7.5 inches)
Postcards
100 x 148 mm (3.94 x 5.83 inches)
148 x 200 mm (5.83 x 7.87 inches)
Transparency films
Labels
Photo (matte or glossy laser photo paper only)
102 x 152 mm (4 x 6 inches)
Custom
Printing specifications
Specification
Details
Print quality, black
Up to 600 x 600 dpi
Print quality, color
Up to 600 x 600 dpi
Resolution technology
HP ImageREt 2400, Ultraprecise toner, HP edge-enhancement
Language
HP PCL 6, HP PCL 5c, HP postscript level 3 emulation, Hybrid print path
Print speed
First page out
Monthly duty cycle
Up to 30,000 sheets of paper
note: |
Recommended monthly print volume
250 - 1000 sheets of paper
note: |
Duplex printing (printing on both sides of paper)
Manual (driver support provided)
Memory card specifications
note:The HP Color LaserJet CP1515n does not support memory cards.
Maximum recommended number of files on a memory card
Maximum recommended individual file size
2000
8 MB
note:Approaching any of the recommended maximums on a memory card might slow the performance of the product.
Supported memory card types
CompactFlash Type 1 and 2
Memory Stick Duo
Memory Stick
Memory Stick Pro
Secure Digital
MultiMediaCard (MMC)
XD-Picture Card
note:Other memory cards, including Memory Stick Magic Gate Duo, Memory Stick Duo, and Secure Multimedia Card, are supported with the use of an adapter. See the instructions that came with your memory card for more information.
Power specifications
The following tables contain the power specifications for the product.
caution:Power requirements are based on the country/region where the printer is sold. Do not convert operating voltages. Doing so might damage the printer and void the product warranty.
Specification
110-volt models
220-volt models
Power requirements
Minimum recommended circuit capacity
4.5 A
2.5 A
Environmental specifications
The following information contains the environmental specifications for the product.
Recommended operating conditions
Environment
Recommended
Allowed
Temperature
17 to 25 °C (62.6 ° to 77 °F)
15 to 30 °C (59 to 86 °F)
Humidity
20% to 60% relative humidity (RH)
10% to 80% RH
Altitude
Not applicable
0 to 3048 m (0 to 10,000 ft)
Energy Star
This product is designed to reduce power consumption and save natural resources without compromising product performance. It has been designed to reduce total energy consumption both during operation and when the device is not active. This product qualifies for ENERGY STAR®, which is a voluntary program established to encourage the development of energy-efficient office products.
ENERGY STAR is a U.S. registered service mark of the U.S. EPA. As an ENERGY STAR partner, HP has determined that this product meets ENERGY STAR guidelines for energy efficiency.
For more information, go to the Energy Star website (in English).
Materials safety data sheets
To view Material Safety Data Sheets (MSDS), go to http://www.hp.com/go/msds (in English).
Ozone production
This product generates no appreciable ozone gas (O3).
Paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309 and EN 12281:2002. Plastic parts over 25 grams (0.88 ounces) are marked according to international standards that enhance the ability
to identify plastics for recycling purposes at the end of product life.
Recycling program
HP offers an increasing number of product return and recycling programs in many countries and regions,
and partners with some of the largest electronic recycling centers throughout the world. HP
conserves resources by reselling some of its most popular products. For more information about the recycling of HP products, go to www.hp.com/go/recycle (in English).
Regulatory specifications
The following information contains the regulatory specifications for the product.
Exposure to radio frequency radiation
The Center for Devices and Radiological Health (CDRH) of the U.S. Food and Drug Administration has
implemented regulations for laser products manufactured since August 1, 1976. Compliance is
mandatory for products marketed in the United States. The device is certified as a “Class 1” laser product
under the U.S. Department of Health and Human Services (DHHS) Radiation Performance Standard
according to the Radiation Control for Health and Safety Act of 1968. Since radiation emitted inside the
device is completely confined within protective housings and external covers, the laser beam cannot
escape during any phase of normal user operation.
warning:Using controls, making adjustments, or performing procedures other than those specified in this user guide might result in exposure to hazardous radiation.
