    Fix HP Printer issue on macOS
HP Color LaserJet CP2020 Printer Series - HP Embedded Web Server
The HP Embedded Web Server (HP EWS) is a Web server in the product that allows users to control settings on the HP Color LaserJet CP2020 Series printer through the Web browser. The HP EWS is available only if the HP Color LaserJet CP2020 Series printer is installed through a network rather than a USB connection.
To gain access to the HP EWS, open a Web browser and type the printer IP address in the address bar.
The printer IP address is documented on a configuration page. Print a configuration page by following these steps on the product control panel:
  1. Press OK to open the menus.
  2. Press the Left arrow or Right arrow to navigate to Main menu/Reports. Press OK.
  3. Press the Left arrow or Right arrow to navigate to Reports/Config report. Press OK.
  4. Find the IP address on the printed sheet beneath the Product Settings heading.
The following tabs are available in the HP EWS:
Status tab
Use the Status tab to gain access to and print detailed information regarding product and supply status, product configuration, network configuration, and usage.
The Status tab contains the following screens:
Device Status
The Device Status screen shows status messages from the product. The Device Status screen also contains some pertinent printer information and product settings.
Figure : Device Status
Supplies Status
The Supplies Status screen provides detailed information about the cyan, magenta, yellow, and black print cartridges. This information is not available if a non-HP cartridge is installed in the product.
Figure : Supplies Status
Device Configuration
The Device Configuration screen shows the values for all of the settings available for the product and other configuration items, such as installed DIMMs, personalities, and page counts. The contents of this screen are consistent with the configuration page that the firmware generates.
Figure : Device Configuration
Network Summary
The Network Summary screen shows the values for all of the network settings that are available for the product. The contents of this screen are consistent with the configuration page that the firmware generates.
Figure : Network SummaryStatus
Print Info Pages
Use the Print Info Pages screen to print the internal special pages that the product generates. The content of these reports is generated by the product firmware. Click Print next to the name of the page to be printed.
Figure : Print Info Pages
Color Usage Job Log
Use the Color Usage Job Log screen to complete the following tasks:
  • Find the printer's serial number, which is listed under the Product Information subheading.
  • Check the number of print jobs stored, which is listed under the Usage Totals subheading. The log also includes information about how much color the printer has used.
  • Delete the currently stored Color Usage Job Log information by selecting the Clear Job Log option.
Figure : Color Usage Job Log
Event Log
Use the Event Log screen to monitor events for the HP Color LaserJet CP2020 Series printer. Up to 10 events can appear on this screen. If this screen is empty, no events have occurred on the printer.
Figure : Event Log
Settings tab
Use the Settings tab to view and change settings for the following features:
Device Information
The Device Information screen contains identifying information about the printer.
  • Device Description. This field shows the version of the HP Color LaserJet CP2020 Series printer that is installed.
  • Asset Number. Use this field to assign an identifying asset control number to the printer.
  • Company Name.
  • Contact Person.
Figure : Device Information
Paper Handling
Use this screen to configure the paper-handling defaults for the printer. Change the default settings by clicking the blue arrow next to each option and highlighting the selection. Click Apply to save the new settings.
Figure : Paper Handling
The following options are available.
  • Default paper size. This drop-down menu lists all of the supported paper sizes.
    Because paper-size settings in most software programs override driver settings, use the driver to set paper size only when printing from software programs that do not include a paper-size setting, such as NotePad, or when producing a book or a booklet that does not require different paper sizes.
    Certain software programs can override the size command and specify different paper sizes within a single document.
    When you change the print-driver setting to a paper size that is not currently loaded in the printer, a control-panel message prompts you to load the paper size or select another tray.
  • Default paper type. This drop-down menu shows a selection of the paper types that the HP Color LaserJet CP2020 Series printer supports. When you use the default setting, Unspecified, the printer uses the default paper type, which is usually Plain. For more information about paper types, see Paper type:.
  • Duplex. The duplexing unit in the HP Color LaserJet CP2020 Series product prints on two sides of a sheet of paper when the Print on Both Sides option is specified in the print job. The HP Color LaserJet CP2020 Series product comes with a duplexing unit installed in the following models:
    • HP Color LaserJet CP2025dn
    • HP Color LaserJet CP2025x
    These product models support smart duplexing. The smart duplexing feature increases printing performance by preventing one-page print jobs or single-sided pages of a duplexed print job from going through the duplexing unit even when the duplexing feature has been selected in the driver.
    All paper types support the smart duplexing feature, except for paper types that cannot be printed on both sides (such as labels, transparencies, and envelopes) and the following paper types:
    • Prepunched
    • Preprinted
    • Letterhead
    When the paper type is set to Unspecified, the smart duplexing feature is disabled.
    To achieve the best print quality when printing on the second side of the page, the product needs to make adjustments to its print modes. When you select a paper type, you are, in effect, instructing the product to use a group of settings (such as fuser temperature and print speed) to print the paper with the best possible quality. This group of settings is known as print mode. A different print mode is used with each paper type. Print-mode adjustments for the second side of a duplexed page are automatic.
    For more information about the duplex feature, seeFinishing tab features .
  • Bind. Binding occurs along either the left edge or the top edge of the page. Short-side binding is for print jobs with pages that read by flipping over like the pages of a calendar. Long-side binding is for print jobs with pages that read by turning like the pages of a book.
    For more information about binding, seeFinishing tab features .
  • Tray size and type. Network administrators can use this feature to specify, in the driver, the paper size that is loaded into each available input tray. The use of forms constrains the choices that are available in the paper-size list on the Paper/Quality tab in the Printing Preferences driver tab set. This constraint prevents (or reduces the likelihood of) tying up the printer with paper-mount messages that occur when users request sizes or types that are not available.
    The trays listed on this screen include standard trays and optional accessory trays. Generally, items that are installed separately have a separate Installable Options setting.
    The input trays listed here are also listed as paper sources on the Paper/Quality tab.
Printing
Use the Printing screen to change the printing defaults for the printer.
Figure : Printing
  • Copies. This setting specifies the number of copies to print. This driver setting is useful for software programs that do not provide a copy count. If a copy count is available in the software program, set the copy count in the software program.
    The requested number of copies appears in the Copies option. Select the number by typing in the box or by using the up and down arrows on the right side of the text box. For the HP Color LaserJet CP2020 Series printer, valid entries are numbers from 1 to 9999. The copies value will not advance from the maximum number (9999) to 1 when the up arrow is used, or change from 1 to the maximum number (9999) when the down arrow is used.
    Invalid entries into the edit box (such as non-numerical input, numbers less than 1, or numbers greater than 9999) change to the last valid value that appeared in the box. The default number of copies is 1.
    Problems can develop when a software program and the driver it is running on both allow the user to set the number of copies to print. In most cases, the software program and the driver communicate, so that the number of copies set in one location (such as the program) appears in the other (such as the driver). For some software programs, this communication does not take place, and the copies values are treated independently. For example, setting 10 copies in the program and then setting 10 copies in the driver might result in the printer making 100 copies (10 x 10). Set the number of copies in the software program, whenever possible.
  • Orientation. Use this feature to choose the direction of the print job.
    • Portrait. The top edge of the document is the shorter edge of the paper. This is the default setting.
    • Landscape. The top edge of the document is the longer edge of the paper.
PCL5c
Use the PCL5c screen to change font information and form length.
Figure : PCL5c
PostScript
Use the PostScript screen to turn postscript error printing on or off.
Figure : PostScript
The Print PostScript errors setting specifies whether a PS error-handler message is sent. To get the printer to print an error page when an error occurs in the print job, click On.
Print Quality
Use the Print Quality screen to change when and how often the printer calibrates. You can also use the Calibrate Now button on this screen to cause the printer to calibrate.
Figure : Print Quality
Print Density
Use the settings on the Print Density screen to adjust the amount toner the printer uses for images, pages, and documents.
Figure : Print Density
Paper Types
Use the Paper Types screen to map the print modes that the printer will use for each paper type.
For more information about Paper Types settings, see Paper type:.
Figure : Paper Types
Extended Print Modes
Use the Extended Print Modes screen to adjust the printing process to optimize print quality for various paper types and sizes.
For more information about Extended Print Mode settings, see Extended Print Modes screen.
Figure : Extended Print Modes
For more information regarding the Optimize menu options, see Optimize modes.
System Setup
Use the System Setup screen to change settings on the printer such as Jam Recovery and Auto Continue.
Figure : System Setup
Service
Use the Service screen to start the cleaning mode procedure on the printer. Follow the instructions on the product control panel to complete the cleaning procedure.
Figure : Service
Password
Use this screen to set or change the Administrator password.
Setting a password on this screen also sets the password for HP ToolboxFX.
Figure : Password
Networking tab
Use the Networking tab to view and change settings for the network connection and communication with the printer. The following screens are available:
Network Summary
The Network Summary screen that appears on the Networking tab is the same screen that appears on the Status tab. See theNetwork SummaryHP EWS (Windows)Network SummaryNetwork SummaryHP EWS (Windows) in the Status tab section for more information about this screen.
IPv4 Configuration
Use the IPv4 Configuration screen to modify settings for basic TCP/IPv4 Network configuration.
If Automatic IP is configured, the Manual IP Address configuration settings are disabled, but the values for these settings are still displayed if they have been set.
If the configuration is switched from Automatic IP to Manual IP, the IP Address fields are cleared, and the desired IP Address must be entered before continuing.
Click Apply to keep changes. When Apply is clicked, a confirmation dialog asks for confirmation. Click Yes to continue.
Figure : IPv4 Configuration
IPv6 Configuration
The IPv6 Configuration screen shows the status of the IPv6 Network configuration settings. This screen is read-only and no settings can be modified here.
Up to seven IPv6 addresses can be shown on this screen, depending upon the automatic configuration of the networking firmware. All available IPv6 addresses are shown.
Figure : IPv6 Configuration
Network Identification
Use the Network Identification screen to configure the host name and domain name(s) used to identify the product on the network.
The values for host name and domain names are retrieved from the firmware and displayed on this screen. The networking firmware determines what host name and domain name(s) to use and cannot be modified.
The text entries are disabled under certain circumstances. The following table defines when the entities are disabled.
Network Identification screen – Text entries
Text entry
Disabled status
Host name
Disabled if configured by BOOTP
Domain name (IPv4/IPv6)
Disabled if configured by BOOTP, DHCPv4, or DHCPv6
Domain name (IPv6)
Disabled if configured by DHCPv6
Bonjour Service name
Disabled if Bonjour is disabled
Figure : Network Identification
Advanced
Use the Advanced screen to configure the enabled settings and other settings, such as link speed, for the printer.
Figure : Advanced
Advanced Network Settings options and settings
Option
Settings
Enabled Features
  • HP SLP Discovery (enabled by default)
  • LPD Printing (enabled by default)
  • Show IPv4 address on conrol panel
  • IPv4
  • IPv6
  • Bonjour
  • WS-Discovery
  • DHCPv6
Other Settings
Restore all network settings to their factory default values.
Click Apply to make the changes take effect.
SNMP
Use this screen to configure the SNMP networking settings for the printer.
Figure : SNMP
The following options are available on the SNMP screen:
Options
Enable SNMP v1 read-write access
Select this option to enable SNMP v1 agents on the printer. Custom community names can be configured to control management access to the HP Color LaserJet CP2020 Series printer. These community name settings appear on the lower half of the screen.
Set Community name:
Type the SNMP Set Community Name (password) to allow SNMP information to be configured (or written) on the printer.
Confirm Set Community name:
Retype the SNMP Set Community Name (password) to allow SNMP information to be configured (or written) on the printer.
Get Community name:
Type the SNMP Get Community Name (password) to allow SNMP information to be read from the printer.
ui.element>Confirm Get Community name:
Retype the SNMP Get Community Name (password) to allow SNMP information to be read from the printer.
Disable SNMP v1 default Get Community name of “public”
Select this option to disable the default Get community name "public". After selecting this option, type the values in the Get Community name and Confirm Get Community name fields.
Enable SNMP v1 read-only access (uses “public” for the Get Community value)
Select this option to enable the SNMP v1 agents on the HP Color LaserJet CP2020 Series printer, but limit access to read-only. Write-access is disabled. The default Get Community name "public" is automatically enabled.
Set Community name:
Configure Get Community name:
Disable SNMP v1 default Get Community name of “public”:
Disable SNMP v1
Select this option to disable the SNMP v1 agents on the HP Color LaserJet CP2020 Series printer, which is recommended for secure environments. If SNMP v1 is disabled, some port monitors or discovery utilities might not operate properly.
Apply
