    We are upgrading our website
HP Compaq dx2300 Microtower PC - Removing and Replacing the Memory
This document is provided to assist in removing and replacing the Memory for the HP Compaq dx2300 Microtower PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the Memory that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
256 MB, 667 MHz, CL=5, PC2-5300 DDR2-SDRAM DIMM memory
396519-001 (Modified)
Yes
512 MB, 667 MHz, CL=5, PC2-5300 DDR2-SDRAM DIMM memory
396520-001 (Modified)
Yes
398038-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Memory, click on the link below. Or use the product video listing on the HP Services Media Library then select Memory from the menu on the upper left hand side of the screen.
Click here to view the Memory removal video (right-click on the link to open in a new window/tab).
Memory removal
    This system uses DDR2 PC2-5300 DIMMS. There are two DIMM sockets on the system board: XMM1 and XMM2.
  2. Push down and out on the memory socket latches to release the memory module.
  3. Pull the memory module up and out of the socket.
Memory replacement
  1. Ensure that the memory socket latches are pushed down and away from the memory socket.
  2. Match the notch on the memory module with the key in the memory socket.
  3. Push the module down firmly into the socket until the latches snap into place.
  4. Ensure that the module is fully inserted and properly seated in the socket.
Country: Flag Vietnam
