    Looking for Site Help?
HP Compaq dx2300 Microtower PC - Removing and Replacing the PCI card
This document is provided to assist in removing and replacing the PCI card for the HP Compaq dx2300 Microtower PC.
Minimum skill level
Tools required
Torx-15 screwdriver.
Parts required
The replacement part number will vary depending on the PCI card that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
ATI Radeon X1300 PCI-Express graphics board - Video board with 256 MB DDR SDRAM memory, one DVI-I digital display output, and one 4-pin (F) mini-DIN (S-video) TV output
413023-001 (Modified)
Yes
PCIe ATI Radeon X1300 (RV516) graphics controller card - 256 MB DDR2 SDRAM, dual-head
432747-001 (Modified)
Yes
Belkin wireless LAN (Rest Of World) 802.11a/b/g PCI card
391866-001 (Modified)
Yes
Belkin wireless LAN (Americas) 802.11a/b/g PCI card
391866-002 (Modified)
Yes
IEEE 1394 (FireWire) low profile interface card - 400, 200, 100 Mbps data rates
393308-001 (Modified)
Yes
Intel Pro/1000 PT Gigabyte Ethernet PCIe network interface card - Has one RJ-45 connector
398754-001 (Modified)
Yes
Agere Systems PCI SoftModem - High-speed 56 Kbps, V.92 modem card
398661-001 (Modified)
Yes
DVI-I to VGA adapter - From a (M) DVI-I connector to a (F) 15-pin VGA connector
202997-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the PCI card, click on the link below. Or use the product video listing on the HP Services Media Library then select PCI card from the menu on the upper left hand side of the screen.
Click here to view the PCI card removal video (right-click on the link to open in a new window/tab).
PCI card removal
  2. Disconnect any cables attached to the PCI card.
  3. Remove the Torx-15 screw and then lift and remove the PCI retention clamp on the rear of the chassis.
  4. Pull straight up on the card to remove it from the PCI slot.
    If not replacing the PCI card with another card, cover the open slot on the PCI bulkhead with a metal slot cover.
PCI card replacement
  1. If you are installing a new PCI card, remove the slot cover from the appropriate slot on the PCI bulkhead.
  2. Align the connectors on the PCI card with the PCI slot on the system board.
  3. Press the card firmly into the slot. Make sure the card is seated properly.
  4. Insert the tabs on the PCI retention clamp into the slots on the chassis and lower the clamp into place.
  5. Replace the Torx-15 screw to secure the clamp to the chassis.
  6. Connect any cables needed to the PCI card.
Country: Flag Vietnam
