    Looking for Site Help?
HP LP2275w and LP2475w LCD Monitors - HP LP2475w Model
HP LP2475w Model
HP LP2475w Specifications
Type
60.96 cm wide screen
TFT LCD
24 inches wide screen
Viewable Image Size
60.96 cm diagonal
24–inch diagonal
Tilt Adjustment
-5 to 30°
Swivel Adjustment
-45 to 45°
Height Adjustment
110 mm range
3.94–inch range
Pivot
Clockwise
Maximum Weight (Unpacked)
9.3 kg
29.1 lbs.
Dimensions (include base)
Height (maximum)
Depth
Width
52.1 cm
25.3 cm
55.6 cm
20.5 inches
10 inches
21.9 inches
Maximum Graphic Resolution
1920 x 1200 (75 Hz) analog input
1920 x 1200 (75 Hz) digital input
Optimum Graphic Resolution
1920 x 1200 (60Hz) analog input
1920 x 1200 (60Hz) digital input
Text Mode
720 × 400
Dot Pitch
0.270 (H) × 0.270 (W) mm
Horizontal Frequency
30 to 94 kHz
Vertical Refresh Rate
48 to 85 Hz
Environmental Requirements Temperature
Operating Temperature
Storage Temperature
5 to 35° C
-20 to 60° C
41 to 95° F
-4 to 140° F
Relative Humidity
20 to 80%
Power Source
90 – 265 VAC, 45/63 Hz
Altitude:
Operating
Storage
0 to 3657.6 m
0 to 12192 m
0 to 12,000 feet
0 to 40,000 feet
Power Consumption (maximum)
<120 watts
Input Terminal
Two DVI-I connectors with DVI to DVI-D and DVI to VGA cables included; one DisplayPort connector with cable included; one HDMI connector with cable included; one Composite connector; one S-Video connector; one set of Component connectors
Country: Flag Vietnam
