The document Instructions on How to Reinstall the T5xxx Operating System provides an overview of the HP Compaq Thin Client Imaging Tool for HP Compaq Thin Client t5000 Series, and instructions for obtaining and deploying the restore image.
- ${title}
- ${title}
- ${title}
- ${title}
HP Compaq Thin Clients - How To Reinstall the Operating System on an HP Compaq ThinClient
Details
The HP Compaq Thin Client Imaging Tool is part of the Package-for-the-Web deliverable that contains the original factory image for the HP Compaq t5000 Series Thin Client. Go to Instructions on How to Reinstall the T5xxx Operating System, or select the following options:
Go to the HP Support website.
Type your model number in the Enter your product name or serial number box. For example, type HP Compaq t5125 Thin Client, and then click Find. If a list of model numbers displays, select your model number from the list.The product page displays.
Scroll down the page, and then click How to.
Click Instructions on How to Reinstall the T5xxx Operating System.
Go to HP Thin Client Imaging Tool for more information.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
