HP iPAQ 900 Business Messenger Series - Configuring an Existing Windows Live Account on the Device
Use the Microsoft Windows Live application to set up your existing Windows Live account on the HP iPAQ 900 Business Messenger series.
Accessing your Windows Live account from the device
  1. Make sure your device is connected to the Internet.
    Please check with your service provider or the wireless operator to confirm if the data connection is enabled on your device. You can also refer to the Product Guide for more Internet access specific information.
  2. Tap Start > Programs > Windows Live.
  3. Tap Sign in to Windows Live.
  4. Tap Accept.
  5. Type your Microsoft Hotmail, live, or MSN e-mail address in the E-mail address box.
    From the drop down list, select Other if your e-mail address is from a provider other than Microsoft.
    Figure : E-mail provider list screen
  6. Type your password.
  7. Tap Next.
  8. Select the desired services.
    Figure : Services options screen
  9. Select the appropriate option to store Windows Live contacts in the device's contact list.
    Figure : Store Windows Live contacts screen
  10. If you would like Windows Live to sync your e-mail, select the Sync e-mail check box.
  11. Tap Next.
  12. Tap Done when the synchronization is complete.
To switch Windows Live user accounts, tap Start > Programs > Windows Live > Menu > Account Options > Switch Windows Live ID. When prompted, tap yes. Your current Windows Live user account settings gets cleared and you need to re-create another Windows Live user account.
