    Looking for Site Help?
HP iPAQ 900 Business Messenger Series - Setting Ring Tones and Troubleshooting
Use the Phonefeature on the HP iPAQ 900 business messenger series device to change the ring tone and the ring type. You can also use the HP iPAQ RingTones application to add, delete, and manage ring tones on your device.
The HP iPAQ RingTones application only adds and deletes ring tones. This application will not help you specify any file as your current ring tone.
Changing the ring tone and the ring type
Follow these steps to change the ring tone and the ring type.
  1. Tap Start > Settings > Phone.
  2. From the Ring type list, select the ring type.
  3. From the Ring tone list, select the ring tone for the device.
  4. Tap ok to apply the settings.
Adding a ring tone
Follow these steps to add a ring tone.
  1. Tap Start > Settings > System > RingTones > Add. In the IPAQ Ring Tones screen, the Select Ring Tones to add to your device list displays all *.wav, *.mid, and *.mp3 files stored on the device.
    Figure : RingTones Add screen
  2. Select a ring tone.
  3. Tap the (Play) button to play the selected ring tone.
  4. Tap the (Stop) button.
  5. Tap Add.
  6. Tap ok.
Deleting a ring tone
Follow these steps to delete a ring tone.
  1. Tap Start > Settings > System > RingTones > Remove.
  2. From the Select Ring Tones to be removed from your device list, select the desired ring tones.
    Figure : RingTones Remove screen
  3. Tap Remove.
  4. Tap ok.
Assigning ring tone to a contact
Follow these steps to assign ring tone to a contact:
  1. Tap Start > Programs > Contacts.
  2. Select the contact you wish to assign a ring tone to.
  3. Tap Menu > Edit.
  4. Scroll to the Ring tone field, tap space and select the ring tone you wish to assign for that contact.
Assigning text message tone
Follow these steps to assign text message tone:
  1. Tap Start > Settings > Sounds & Notifications.
  2. On the Sounds & Notifications screen, tap the Notifications tab.
  3. In the Event field, select Messaging: New text message.
  4. Select the tone you like from the Play sound field.
Troubleshooting tip
Number of rings
If your want to change the number of rings on your device before the calls or messages are diverted to the voice mails, contact your service provider. The service provider can provide you with options to change the number or rings.
However, as a workaround, follow these steps:
  1. Tap Start > Settings > Phone > Services.
  2. Tap Call Forwarding > Get settings. Change the Forward After option to 30 seconds.
  3. Tap ok.
Country: Flag Vietnam
