HP Compaq dc7800 Small Form Factor PC - Removing and Replacing the PCI card
This document pertains only to HP Compaq dc7800 Small Form Factor PCs with the following case design:
Before you begin
  • Turn off the computer, and then disconnect all cables. Disconnect the Ethernet or modem cable before disconnecting the power cord.
  • Move the computer to a clear, flat, stable work surface over a non-carpeted floor.
  warning:
Video overview (in English)
To view a video demonstrating the procedure for removing the PCI card, right-click PCI card removal video and select Open link in new window/tab.
Replacement part information
The following HP part numbers are known to be compatible with this system:
Part Number
Requires Return
Belkin wireless LAN (ROW) 802.11a/b/g PCI card - Includes full height and low profile I/O brackets and wireless ante
391866-001 (Modified)
Yes
NVIDIA GeForce 8440 GS PCI-e (x16) graphics card - Professional 2D/3D video controller card with 256 MB DDR2 memory
445743-001 (Modified)
Yes
NVidia GeForce 8400 GS 256 MB DH PCIe x16 Card
445744-001 (Modified)
Yes
PCIe interface card - Feature connector for digital visual interface (DVI-D) and serial digital video output
398333-001 (Modified)
Yes
HP FireWire IEEE 1394a 3-Port PCI card
393308-001 (Modified)
Yes
IEEE-1394 (FireWire) interface PCI board
393307-001 (Modified)
Yes
HP Dual band Wireless A and G PCI Lan Adapter
435269-001 (Modified)
Yes
* If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. For more information about returning parts to HP select one of the links below:
PCI card removal
Review the following safety considerations before performing the following steps. Failure to comply with these safety considerations could result in damage to the product.
Step 1
With all cables disconnected from the computer, remove the access panel.
Step 2
Disconnect any cables attached to the PCI card.
Step 3
Pull up on the PCI retention clamp and rotate it back until fully open.
Step 4
Lift straight up on the PCI card to remove it from the slot.
If the PCI slot has a locking tab, push out and hold the locking tab while lifting the PCI card.
Step 5
If you are not replacing the PCI card with another card, cover the open slot in the PCI card cage with a metal slot cover to facilitate proper airflow and cooling of the system.
PCI card replacement
Step 1
If you are installing a new PCI card, remove the slot cover from the appropriate slot on the PCI bulkhead.
Step 2
Align the connectors on the PCI card with the slot on the system board.
Step 3
Press down on the PCI card until it is fully seated.
Step 4
Rotate the PCI retention clamp down over the PCI bulkhead.
Step 5
Connect any cables to the PCI card.
Step 6
Replace the access panel.
