HP iPAQ 310 Travel Companion Series - Using Traffic Message Channel Car Charger
Issue:
The Traffic Message Channel (TMC) car charger accessory (P/N:FB055AA) does not work with the HP iPAQ 300 Series Travel Companion when trying to obtain traffic information and updates.
Cause: The TMC car adapter uses information and messages transmitted using radio frequencies. So, a TMC data provider or service is required.
Solution
This accessory is available only in the EMEA region, currently. Also, the TMC radio service is not present in all countries.
Find out if this service is available in the country where the HP iPAQ 300 Series Travel Companion is used, and then sign up with a service provider. The service charge fee depends on the service provider.
Then updated traffic information can be obtained while driving. The TMC car adapter accessory connects to a power socket (via the cigarette lighter port in an automobile), and hence gives constant connectivity.
Scope: All models of the HP iPAQ 300 Series Travel Companion
